still problems...
Old Mar 28, 2007 | 09:30 PM
Jake331's Avatar
Jake331
still problems...
ok let me tell you what all is new... injectors, fuel return line kit, fuel filter, fuel pump, glow plugs , glow plug relay. its running really good now my problem was I was using the front fuel tank and the fuel coming from it looks like syrup. so I switched to the rear and it runs fine but still cranking problems. it starts easily with a mist of starting fluid. even after sitting only an hour it won't start. but this morning was the first time it has started by itself. I had the block heater plugged in ( even though it wasn't cold outside) and it took it probably 10 to 15 seconds to start. its a 91 7.3... any suggestions?
Old Mar 28, 2007 | 09:37 PM
dwaymar's Avatar
dwaymar
almost sound like you need to check the glowplugs if not the motocraft from az then this can happen
Old Mar 28, 2007 | 10:09 PM
PLC7.3's Avatar
PLC7.3
You changed GPs......what brand did you install....... How long does the Wait to start light stay on......
Old Mar 28, 2007 | 10:22 PM
vintage super duty's Avatar
vintage super duty
my wait to start light seems to stay on long enough but my truck wont start right away unless i cycle the gps 3 to 4 times do you think my compretion is getting low mine is also a 91 7.3
Old Mar 29, 2007 | 07:42 AM
dwaymar's Avatar
dwaymar
what brand of gp
Old Mar 29, 2007 | 09:39 AM
Dave7.3's Avatar
Dave7.3
Make sure you have Motorcraft/Beru plugs as recommended, most others are junk. Test all the GP's and test the GP controller while you are at it. My rig used to have the same sort of starting problem. Soon as the injector return lines and my controller were replaced it starts and runs like a champ. Hope this helps.
-Dave
Old Mar 29, 2007 | 04:36 PM
DNewton's Avatar
DNewton
if your gps are all good, i would check your starter, my truck has the same problem, starter turns it, but not fast enough, with a little ether(gps not on) itll spin the motor just fast enough to start her up.........as soon as i get the money, im going down to napa and getting a new mitsubishi gear reduction starter!!!!!
