6r80 fluid too high?
Old Jul 24, 2020 | 01:33 PM
  #31
ford390gashog's Avatar
ford390gashog
Its overfilled, there should be no fluid coming out with the trans at temperature and running.
Old Jul 24, 2020 | 07:49 PM
  #32
rsylvstr's Avatar
rsylvstr
thank you. I sucked out 7 1/2 ounces. Kept checking it. I drove the daylights out of it until I got it up to 206°. It cooled down very quickly. Said it was 195 or so when I checked it. Checked it like 10 times burnt myself five times. Should be good. So it’s just over 8 quarts I believe with the pan drop.
just got back from towing a 14 foot aluminum boat with aluminum trailer and gear and 20 hp motor, rural with a little suburban area in the mix. Not sure how much it weighs. I think around 1200 pounds. 190°.
Old Jul 24, 2020 | 08:09 PM
  #33
rsylvstr's Avatar
rsylvstr
and it expands, as it gets hot, correct?
So when I opened it the other day when it was still cold, definitely shouldn’t of been pouring out with the truck off, correct?
and when I check it operating temperature, which is about 190 to 195, it shouldn’t even dribble out correct?
thanks for the help and patience.
they should’ve measured what came out.
Old Jul 24, 2020 | 08:22 PM
  #34
ford390gashog
Yes cold and the truck off it will pour out this is because of torque converter drain back. Cold running and it will show low on the dipstick.
Old Jul 24, 2020 | 09:09 PM
  #35
rsylvstr's Avatar
rsylvstr
thank you.
Old Jul 25, 2020 | 06:17 PM
  #36
2jhanna's Avatar
2jhanna
Several years ago I added a trans cooler to the front of mine, didn't have it from factory, afterwards I knew I would need to add fluid. After letting everything get to operating temp, made sure I was on level ground, with engine running, I removed the cap and stubby dipstick, and topped off fluid "like normal".
i used the quart bottle with a pointed nipple cap and attached a short piece of hose, a squirted in a little at a time. Kept rechecking and adding until at the hot level. Wasn't hard or tricky, just laying on your back.
Old Aug 15, 2020 | 12:02 AM
  #37
jason342's Avatar
jason342
fill level erratic
I've had problems with the 6R80 since 100k. I'll get the temp up, shift into each gear as the procedure says, then check fluid on level ground. Shows low about a quart. I add fluid to the top of "A" per the procedure. Shifts fine for a week or so.
Now it's back to shifting way early and hard so I have no power - also shifts really hard when cold. I check the fluid using the 6r80 procedure and now its overflowing... Im thinking this is a solenoid issue rather than "you did it wrong". Anyone seen this before?
Pretty sad how much im going to lose on this truck if I decide to trade for a another one.. not sure I'll be getting a Ford after all of the issues with this one - particularly with the 6R80.
mannermauler
Jul 22, 2019 10:07 PM
Maillemaker
Sep 29, 2018 11:16 AM
svfetter
May 21, 2014 11:40 AM
Sw1tchfoot
Jun 9, 2012 06:22 AM
monty0
Nov 6, 2006 09:29 PM
