2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Infamous mini trans dipstick
Old May 18, 2014 | 09:51 PM
svfetter's Avatar
svfetter
Just checking out the baby dipstick that so many are aware of on these newer expeditions. I removed the plug per instructions to access small plastic dipstick to check fluid level and fluid immediately began to run out.
Truck had been setting for several hours and all fluids were cold. Engine was not running. I know you are supposed to check with engine running. How can you check level when you can not remove plug without fluid leaking? Would it make that much difference in fluid level in the lower pan, not running vs running?
What am I missing?
Old May 19, 2014 | 02:07 PM
bunky383's Avatar
bunky383
The torque converter is empty with truck not running causing a higher fluid level. Start truck and then pull dipstick out to measure
Sent from my Z10 using IB AutoGroup
Old May 20, 2014 | 10:26 PM
travelinl22's Avatar
travelinl22
Starting the truck works
Old May 21, 2014 | 11:40 AM
berry1234's Avatar
berry1234
What am I missing?-See first sentence
Um....you answered your own question.
brian931
2009 - 2014 F150
36
Aug 15, 2020 12:02 AM
Budman1962
Jul 29, 2013 06:26 PM
Sw1tchfoot
Jun 9, 2012 06:22 AM
mikey v
2009 - 2014 F150
23
Mar 7, 2012 04:33 PM
pablocruz69
Jun 2, 2011 11:53 AM
