Bad Headlight Switch, or stomp switch?
Old Sep 21, 2012 | 04:40 PM
Twilight Fenrir's Avatar
Twilight Fenrir
Hello, I've got an '86 F250... I started my truck at 6am this morning when it was pitch black, pulled the headlight switch, and my headlights did not come on. Everything BUT the headlights did however. The Tail-lights, and various marker lights all lit up. If I step on the stomp-switch, the headlights DO come on, but will only be on in Bright mode. I don't have a wiring diagram, so I'm not sure if the power just goes to the stomp switch and is sorted out there, and sent to the headlights, or if it feeds back to the main headlight switch. Any input on this? Thanks!
Old Sep 21, 2012 | 04:45 PM
Rogue_Wulff's Avatar
Rogue_Wulff
If you only have high beams, then you either have a faulty dimmer (stomp) switch, faulty wiring, or both low beams are burned out. It's rare that both low beams burn out at the same time, but it has happened occasionally.
Get a test light, check for power at the headlights on the low beam side. If power is getting there, replace the bulbs. If power isn't getting there, trace back towards the dimmer switch. If no power is coming from the dimmer, replace it.
Old Sep 21, 2012 | 04:53 PM
bashby's Avatar
bashby
When I replaced my floor mounted dimmer on my 86, I had to also replace the plug going to it. Napa had it in stock I believe.
Old Sep 21, 2012 | 05:04 PM
Twilight Fenrir
I had a spare bulb laying around, and I had tried hooking it up, no dice. Was one of the first things I did though :P I doubt my wiring went anywhere overnight, so I'll take a look at the stomp switch first. I had fiddled with that the day before. Thanks for saving me some time pulling my dash appart to check connections at my headlight switch
Old Sep 21, 2012 | 05:10 PM
ctubutis's Avatar
ctubutis
Stomp switch? Never heard of that term before.
Old Sep 21, 2012 | 05:21 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Most likely the dimmer switch or the wiring to the low beam is damaged.
There is only one wire from the headlamp switch to the dimmer switch.
From the dimmer switch to the headlights it powers either low beam or hi-beam.
If you got high beams, it's not the headlight switch.
The dimmer switch and wiring at the floor area is prone to water damage. (wet feet)
Old Sep 21, 2012 | 05:24 PM
Twilight Fenrir
Really? That's the term I've always heard it as :P I knew the correct term was dimmer switch, but most people around here go "Huh?" unless you call it a stomp switch... maybe it's just the old-timers though. :P
Old Sep 21, 2012 | 05:41 PM
ctubutis's Avatar
ctubutis
:P
Hey, do me a favor, go HERE and finish filling out your Profile so we can see where you're at with your posts? Yeah, people can look it up, but it's sometimes more bother than it's worth to do that.
Old Sep 21, 2012 | 05:44 PM
Twilight Fenrir
:P
Huh? I did fill out my profile o.o Didn't I?
Old Sep 21, 2012 | 05:49 PM
ctubutis's Avatar
ctubutis
I asked you to finish filling out your Profile.
All the stuff that's publicly-viewable is in the third pane. The second field - Location - will be shown in the top-right corner of each of your posts.
Old Sep 21, 2012 | 05:51 PM
Twilight Fenrir
There, happy? :P
Hehe, thanks, silly me, I assumed the area right below it that mandated my location was good enough.
Old Sep 21, 2012 | 06:28 PM
81-F-150-Explorer
It helps us to know a general location, due to smog compliance and other technical issues that vary by region.
Old Sep 21, 2012 | 06:31 PM
Twilight Fenrir
Haha, I'm not complaining. I'm happy to do it, just making fun is all... As for smog compliance... No such thing in Minnesota. 'least not up here.
Old Sep 21, 2012 | 07:24 PM
Rovernut's Avatar
Rovernut
I'd consider myself an old timer (I was grown before I saw my first column mounted dimmer) We always had floor mounted dinners
Could be a regional thing, like bag, sack, poke, etc.
Old Sep 21, 2012 | 10:38 PM
Rogue_Wulff
Most younger folks have no clue how to dim/bright the lights on older vehicles. Me, I have trouble getting my foot up by the steering wheel.........
