I am an idiot please help.
#31
Good luck op.I put on a locking fuel neck gas cap just to make me think a little more for situations when im filling def.Might save my but one day when Im not paying attention.But atleast you had the mind enough not to even put the key in ignition..Im sure your ok after you drain and flush.DISASTER AVERTED.I bet it wont happen again.
#33
Curious. Is putting DEF in the tank worse than putting gasoline?
I am asking because I follow the Long Long Honeymoon people and he has filled up, more than once I believe, the diesel with gas and then had it pumped out (before starting). One dumb mistake, jump to 5:40
There is no way they got every last drop out that way, yet he has not had problems related to this. His truck is pre-DEF. Are our DEF trucks more fragile or is DEF worse than gasoline to a diesel?
#34
#35
I am bad about updating my Sig. I use this to make my money. Drove it off the lot Oct 23 with 30 miles on it. I am now right around 18,000. So I have filled the def tank a few times now. Just pushing away on buttons on the pump and taking cap off at the same time. Habit I fill just about every day. And Rob I would like to think you are right about it not happening again. I am so disgusted with myself.
I will get back with yall tomorrow and give an update. The irony of it all is I was actually thinking about working on the 7.3 tomorrow and try and see why it quit on me. Oh well at least I know it doesnt have a DEF problem.
thanks again guys.
thanks again guys.
#36
#37
#38
Not sure the effect of gasoline on a diesel but my son's buddy put gas in his diesel my mistake and when it quit running they towed it home and pumped the tank and changed the filters, after priming a few times it started up and has ran fine since. It was under warranty so it wasn't going to the dealer.
#39
I am ford sm diesel tech. I since engine or fuel system has not been operated
I remove bed if possible remove fuel sender , drain tank completely & wipe it dry.
remove lower fuel filter & replace. remove fuel line at secondary (upper) filter from
tank . adddclean diesel to tank & flush lines .replace upper filter . Add pm 22 or your choice of additive w/fuel lube. You are not an idiot you did not start the truck.
even if dealer does this it would not affect warrenty
#40
#41
Thanks guys for going easy on me I expected some consequences in the way of commments when I posted this, and rightfully so.well it is done it has been five hours since the primary filter was removed and no crystal growth on it. I dropped and cleaned the crap out of the tank, dried it and whipped it down with some diesel clean fuel tank cleaner, add about 10 gallons of fuel with more diesel clean tank cleaner, and now ready to go fill it up and put some more DC in it. I would like to think that I learned my lesson and I will not be doing that again.
thank you all again
Joe
thank you all again
Joe
#42
thank you all again
Joe
thank you all again
Joe
Good deal! Hope all goes well with you.
I have family south of you down in Buffalo. I go thru Harrisonville when I head over to Clinton and down Hwy13 to Boliver then to Buffalo. I'll wave next time I go by.
#43
Wow and you are in Wyoming? I had an uncle that used to live in Buffalo. Now Osceola and Collins.
#45
My MIL's family homesteaded north of Buffalo back in the 1800's. She moved back down there in about 1990. My BIL lives there too. Wife and I will be there sometime this summer.
tuxedobuttonquail
07-26-2017 06:10 PM
