PCM code
Old Mar 28, 2014 | 06:42 PM
milehi_350's Avatar
milehi_350
PCM code
Hey guys, how can you tell what PCM code is on a reman? Also is there a 'standard' code for an '03? I was wanting to let a friend try my f5 but not sure if it will work right in his truck. Mine is a pmt3.
Old Mar 28, 2014 | 07:01 PM
t.scottNDU's Avatar
t.scottNDU
Mine is VDH5, I believe. Haven't seen any other '03's though. Have you tried pulling it out and looking it over?
Old Mar 28, 2014 | 07:03 PM
milehi_350's Avatar
milehi_350
Haven't seen it in person but he sent me pics of it and I can't see anything that resembles the four digit code.
Old Mar 28, 2014 | 08:30 PM
white Buffalo's Avatar
white Buffalo
Here is a pic of the one I took out of my 2000 Excursion - AXDO.
On my 2003 F-250 the PCM code is VDH5 as well.
Old Mar 28, 2014 | 08:31 PM
HKusp's Avatar
HKusp
Mine is VDH5 as well.
Old Mar 29, 2014 | 11:23 AM
t.scottNDU's Avatar
t.scottNDU
That's where I was going to suggest looking. Pull the PCM and see if that black snap-in cover is still on there. If so, the code should be on there.
Old Mar 29, 2014 | 12:13 PM
milehi_350's Avatar
milehi_350
He didn't send pic of that part. I guess the thing to do is call dp and ask them if my chip is compatible with his PCM. Maybe it's all a moot point because my chip is programmed with my bts vb in mind, so it would take a re-burn anyway.
Old Jun 17, 2015 | 11:58 AM
dray615's Avatar
dray615
2000 F-250 7.3 PCM Issues
I need help real bad!
I have a 2000 F-250 7.3 and just as of yesterday I started blowing the #24 PCM Fuse under the hood. I replaced it and throughout the day ended up blowing a total of 4 fuses. It wasn't until the 5th fuse I installed that I realized that every time It blew, I was at low idle and making a right turn. I have looked for bare wires and so far have found nothing. While on my way home last night I also realized that my cruise control is no longer working. Could this all be related and why is it only when I am turning right that I am blowing fuses? Thank you
Old Jun 17, 2015 | 12:17 PM
hydro man 17's Avatar
hydro man 17
Try unplugging the fuel bowl heater.
Old Jun 17, 2015 | 12:21 PM
Jesser02EX's Avatar
Jesser02EX
For cruise control, check the connector at the end of te hydroboost. It could be disconnect like the pic below.
Old Jun 17, 2015 | 12:24 PM
dray615's Avatar
dray615
I did that and its still blowing fuses. BUT its only happening while I am in motion and turn to the right. VERY WEIRD I KNOW!
Old Jun 17, 2015 | 01:00 PM
dray615's Avatar
dray615
I am not seeing that connector on my truck ad my brake reservoir doesn't look like that. I just found the red vacuum line that comes off the turbo unhooked. I am not sure if I did that yesterday or if it came undone on its on. It plugs in above the heater bowl connector. Could that of been a reason for my problems?
Old Jun 17, 2015 | 07:42 PM
jhl3's Avatar
jhl3
Sorry, I doubt that the red line being disconnected would cause that problem.
Did you try disconnecting the fuel bowl heater as suggested above?
Old Jun 17, 2015 | 09:37 PM
Thomas White's Avatar
Thomas White
The Fuse Circuit #24 is an independent circuit for the PCM alone. It controls no other accessories.
What your experiencing is a short to ground on the supply side of the circuit (if it were on the other side you would have lost your PCM by now, possibly).
I would begin tracing the (+) PCM Wire and working backwards to the ignition switch where it gets its power for the relay.
Somewhere you'll find some wiring issue. Check spices and bundle intersections. Possibly the column itself, its pretty tight in there!
On the bright side, you could run a 12 VDC+ to the PCM fused and REMOVE the other circuit if you can't locate the issue readily. You should do this via a relay directly from the Battery (+) with the Relay activated by the Ignition Switch. While it will work, it is not intended to replace the damaged circuit.
wildstang
Aug 28, 2013 09:52 PM
acf6
Dec 22, 2011 03:38 PM
stroke-of-luck00
Oct 22, 2007 07:34 PM
RDC F250 7.3
Oct 8, 2007 10:00 AM
t.j.g.
Jan 2, 2005 01:00 PM
