Exactly. At $4-500 a set, they are kind of expensive.
I have one set on my main truck, and they work just fine(found a rare set "used" for cheap)/
Justin got 450 HP without lifting the heads, so the studs can hold it without issue(on a 7.3 anyway).
But on my other motors, or for future builds, it would be nice to find something that would work "as well as" the ARP studs for <$150 in materials.
Sure, the machine work would cost, but my plan is to figure out cheap home tools for DIYing it, so as *not* to require a machine shop.
They make grade 12 bolts as well, idk if you could find the specific size you need. But it's food for thought...
It may well be different stateside,your market is huge compared to our little bundle of dots in the South Pacific. Here any bolts smaller than half inch are grade 5 only.
And to digress, if the crack in the block is on the outside, and involves the water jacket only it may be possible to repair with soft solder. I have seen this work up to quarter inch gaps.
Reason: More info..
You can't have them shipped in from China or something?
I do know that even standard socket head cap screws that big and long are special order, even here in the USA
If it wasn't siezed, I'd definitely try it. Never took it apart, I got the motor basically thrown in with a working 6.9 at a junkyard for about $200 total.
If it turns out to be savable otherwise, it would be fun to get running again just for the cool factor.
Just stumbled upon this. Thanks for finally giving is real data on putting larger threads into a 6.9 block. It really is interesting to see all of the old ways of thinking collapse with all of this new data.
In your calculations, it appears you are using the bolts minor diameter to determine clamping load. If this is the case, and if you are using the same P=T/KD calculation I am, a smaller bolt at the same torque will provide more clamping load (P). I guess I never actually sat down and thought that one through. Its interesting to see that we can get a 1/2-13 head bolt into a 6.9 block. Although the same calculation shows that with a larger stud, a higher torque rating will be required on a 1/2" stud to overcome the larger diameter than the 7/16" stud?
So the question I'm wondering, is if you can't drill/tap a 6.9 block all the way for a 7.3 stud, can they still be used as long as its tapped to the correct length? Wonder how much a set of 9/16" studs would run. I suppose the heads would need to be machined to accept the difference?
Both 1/2" and 9/16" studs are available in "close enough" to the same length as the ARP 7/16" kit (6.120")... 1/2" is a bunch less work, but if you have the resources to invest in the machine work, the 9/16" studs will be more clamp load than you could ever use. I tested them as far as my Torque wrench would go without parent thread or fastener failure.
Just to update and offer a warning in this thread because it is info rich....
I just got the heads back on my Bronco engine tonight and I originally had a goal to take the ARP2000 studs to 165ft/lbs for that little extra bit of load (I had them at 160 for the last run with the prototype gaskets)... I ended up pulling the threads out of one hole on the block at the last step (165ft/lbs). Luckily enough, I installed a helicoil, and when I went to torque everything up again, it held 4 passes at 150.
Bottom line, dont take 1/2" fasteners above 150ft/lbs, its not worth the extra gain youll get out of it. 150 is definitely the sweet spot.
[QUOTE=Macrobb;16596509]Exactly. At $4-500 a set, they are kind of expensive.
Morning gentlemen.
im going to replace the head gaskets in the next few days and just want to confirm a few questions before I start.
In the future I plan on putting a turbo on,
1) can I use arp bolts without a turbo on truck?
2) should I put the arp bolts on now or wait till I get turbo
3) is USED from eBay arp bolts a good idea?
4) I was recommended to use a stock head gasket, does everybody agree?
1) Yes
2) I wouldn't want to take the heads back off to put studs in if I didn't have to.
3) I wouldn't buy used head studs, but I've read of others having no issues with it.
4) The stock gasket should be fine for most people, unless you're planning on a really high HP build - in which case, I'm not sure if the new MLS gaskets are available through R&D or not yet.
