Window Help
Old Mar 27, 2014 | 07:46 PM
bruno2's Avatar
bruno2
Window Help
I am going to rebuild my power window motors pretty soon. They have the slow laggy movement. I have seen the help kits to re bush them and have heard about the fuel line trick too.
However, here is an issue that I am not sure of what is going on. The driver side window leans back and forth and will bind up. I am not sure what to expect when I get into it so this is why I am asking now. What part breaks in there to cause this? Also can the part be repaired or does it need to be replaced? If so is a JY part or a new part needed?
Old Mar 27, 2014 | 07:52 PM
Gary Lewis's Avatar
Gary Lewis
If the window "runs" are in good shape the window should not be able to lean back. Does it do that at all heights or just at the bottom?
Old Mar 27, 2014 | 09:10 PM
bruno2's Avatar
bruno2
All heights. You have to move it back into place in order to get it to roll up and down w/o binding.
Old Mar 27, 2014 | 09:29 PM
Gary Lewis's Avatar
Gary Lewis
Then you have badly worn window runs or one of the parts is badly is worn. Here's what it all looks like:
Old Mar 27, 2014 | 10:25 PM
bruno2's Avatar
bruno2
So is it the 22296 and the 222AA00 ?
Do you know where some of those can be had?
Old Mar 27, 2014 | 10:41 PM
bruno2's Avatar
bruno2
Here is a motor repair thread:
https://www.ford-trucks.com/forums/9...-repair-3.html
https://www.ford-trucks.com/forums/1...placement.html
Old Mar 28, 2014 | 07:33 AM
Gary Lewis's Avatar
Gary Lewis
No, it is 21536. The others are the supports, but the runs are the soft material the glass rides in. You can get it at LMC, JBG, etc. but I would pull the door panel and observe the glass in action before buying.
Old Mar 28, 2014 | 09:17 AM
bruno2's Avatar
bruno2
I may have bought a set of those from LMC already.I will look.
Old Mar 28, 2014 | 10:01 AM
JimsRebel's Avatar
JimsRebel
Thanks for posting the links, it was a good read.
I found the plastic and metal gear assembly on ebay for ~ $13
I found my window motors ran a lot faster after I switched from a 2G to a 3G ALT. You might check your battery voltage while running the motor.
http://www.ebay.com/itm/81-92-FORD-PU-Pickup-TRUCK-BRONCO-POWER-WINDOW-LIFT-MOTOR-GEAR-REPAIR-KIT-/310910535678?pt=Motors_Car_Truck_Parts_Accessories&hash=item4863b647fe&vxp=mtr
f-150 on 22's
2004 - 2008 F150
Sep 4, 2007 09:11 AM
boilrman
13
Jan 15, 2007 05:29 PM
Cameo
1978 - 1996 Big Bronco
May 27, 2003 11:42 PM
