1978 - 1996 Big Bronco
91 Bronco
Old Mar 26, 2014 | 07:32 PM
Jxster's Avatar
Jxster
91 Bronco
Yesterday when I was changing the thermostat, flushed the coolant and replaced air charge temperature sensor as simple job and when I was all done and went to start it up and wont start but does crank and wasn't getting any fuel pressure from the rail but don't have the fuel gauge pressure to test it and the relays were working, the resistance is at 0 and wire is getting 12v. I'm lost here and isn't sure what to do next. The fuel pump was replaced a year ago and new fuel filter as well. Thank you for your time.
Old Mar 26, 2014 | 07:57 PM
greystreak92's Avatar
greystreak92
May we assume the truck was running before you made the repairs? Have you pulled Codes? If it was running prior to the repairs, check that nothing has been disconnected or disturbed. If you haven't pulled Codes, you can get KOEO Codes at least and find out if anything had been wrong the last time the truck was run.
Old Mar 26, 2014 | 08:05 PM
Jxster's Avatar
Jxster
It was running good before and the codes were
p0102
p0113
p0171
those codes were pulled before running.
Old Mar 28, 2014 | 01:55 AM
Jxster's Avatar
Jxster
Also, is the engine light supposed to come on when turn the key to on?
Old Mar 28, 2014 | 03:33 PM
greystreak92
Yes, It comes on for a couple seconds to let you know it isn't burned out.
Well for starters, there is no Code 102. The lowest EEC-IV Code is 111. (or 11 if your ECM spits out two-digit Codes).
Code 113: Indicates that the IAT (Intake Air Temperature) (Sometimes referred to the the ACT (Air Charge Temperature) sensor was either pegged above the upper voltage limit or the computer was getting no response from it at all. (i.e. it was disconnected).
Code 171: Indicates that the HEGO (Heated Exhaust Gas Oxygen) sensor was not switching or was sending information causing the entire EEC-IV system to reach its adaptive limit and the computer could still not maintain fuel/air and spark control. A disconnected or damaged O2 sensor will cause this. So will a non-functioning Thermactor air injection pump (failed smog pump). It doesn't have to be completely failed either, it may be as simple as a disconnected vacuum line or hose in the Thermactor plumbing. Frequently when replacing spark plugs, ACT sensor, PCV valve, or other components near the passenger side of rear of the engine, the vacuum lines and hoses running to the Thermactor Air Diverter Valve will dislodge causing no end of headaches. Again the diverter valve is located behind the passenger side cylinder head in all V8-equipped trucks.
Old Apr 3, 2014 | 09:13 PM
Jxster's Avatar
Jxster
Ok after some of testing. I'm getting code of 542. I'm getting 35-40 psi from fuel pressure and tested the fuel pump connector and are at 10-12v and truck isn't starting. What's else I have to do?
Old Apr 4, 2014 | 08:53 AM
jas88's Avatar
jas88
If it was mine I would shoot a little starting fluid into the TB while cranking to see if it fires up. That will tell you if your problem is fuel or spark.
Old Apr 6, 2014 | 02:32 PM
Jxster's Avatar
Jxster
No luck, now I'm getting code of 542 and 543. I tracked down the wiring that wasn't grounded on pin #6 and isn't sure where the wire lead to, all I see the pcm, if it is in there and would I have to remove the pcm to find the ground?
Old Apr 10, 2014 | 02:26 AM
Jxster's Avatar
Jxster
I think I found my problem so all I have to do is to order the connector and the switch but how do I check the switch if its still good to last me?
Old Apr 10, 2014 | 07:56 AM
jas88's Avatar
jas88
What switch are you referring to?
Old Apr 10, 2014 | 05:06 PM
Jxster's Avatar
Jxster
Inertia switch.
Old Apr 11, 2014 | 08:22 AM
jas88's Avatar
jas88
I am confused, if the inertia switch was inop, then your problem would be no fuel, but you said it would not start on starting fluid. That does not add up to me.
Old Apr 11, 2014 | 08:46 AM
Jxster's Avatar
Jxster
I'm getting fuel good, forgot to mention it and all I need is to replace the connector and switch and see from there.
Old Apr 14, 2014 | 05:33 PM
Jxster's Avatar
Jxster
Do anybody know where I can buy fuel filler hose (gas abg 1a10) for my fuel tank, I just need the outside hose and seem it's impossible to find expect at the dealer which is way expensive to purchase. I tried every part shop and is it good idea to pull one from a junkyard not knowing if the hose will last.
Dezerch
Aug 26, 2017 08:07 AM
BocceMon
16
Mar 13, 2017 02:25 PM
KaoticCreations
1983 - 2012 Ranger & B-Series
41
Sep 24, 2009 11:01 PM
fredford55
Jun 28, 2005 02:30 PM
jack1i
Bronco II
Aug 26, 2004 07:31 PM
