My truck will crank but will not fire. My preliminary investigation has left me and my neighbor confused.
Preliminary stuff:
NO fuel pressure at the schrader valve on fuel rail with key on.
A 'click" can be heard from the fuel tank after key is turned on. There used to be a distinctive "clunk" from engine bay when key is turned on, but no longer.
Pulled codes (KOEO) and they are:
11 system pass
66 MAF sensor input is less than maximum voltage. My truck is not MAF
36 I could find no definition for this code, any ideas on this one?
11 system pass
45 Coil 1 & coil 2 primary circuit failure
42 Heated Oxygen sensor (HO2S) circuit indicates system rich.
My neighbor independently pulled the codes and came up withe same as I. They are confusing to both of us. He thinks the PCM is toast.
This is my daily driver & I need to get it up. Any help would be appreciated. I do not know where to go from here.
EDIT: I forgot to add that the engine will temporarily fire using starting fluid.
Reason: more info
Your truck should be a 3 digit code ECM. How are you retrieving codes?.
My truck is obd1 which is 2 digit codes. I was told this on this forum some months ago. I am retrieving codes with a jump wire on the test module and reading the CEL blinks. Jump wire is connected to the single clip on the test module and the lower left on the large one.
Yeah, I'm sorry but whomever told you this is wrong. OBD 1 shows 3 digit codes. Get a equus/INNOVA 3145 scanner, it's inexpensive and will make the job much easier. I'm also fairly sure you have fuel delivery problem, it could be as simple as a loose pigtail connector on the fuel pump or a broken fuel pump (check the fuel system fuse, it could be just that).
Thank you for the link Encho. Looking at 3 digit it would be 116, 636, 114 and 542. Several of these codes seem to tie into the problem. I have two questions then. What is the IAT? and why did I not get a 111 system ok?
You didn't get the 111 code since there are several problem codes listed. Regarding the 114 code, it's the IAT (Intake Air Temperature) the name should be self-explaining, but it shouldn't cause a non-running condition, at most it would make the truck run rough. 116 points at ECT (Engine Coolant Temperature) sensor, it can cause the truck engine to run briefly then die. 636 probably points at either a bad reading from the transmission or overheating trans (not important right now, but look into it whenever possible). 542, this is the one you need to look into, definitely the cause of your no-start condition since it points at a problem with either the power supply to the fuel pump or the fuel pump itself, what I told you before is a good starting point to begin testing/checking. The ECM seems to be in good working order, or at least showing what it should.
Thank you for that explanation Encho. It's dark here now so I will pursue this tomorrow. My apologies on the code snafu earlier. I am glad to have a direction to pursue, thanks again.
Codes 114, 116 and 636 are most likely caused by not warming up the truck before running the KOEO tests. When the truck does not run, I would expect these codes.
Ford started to transition from two to three digit codes in 1991. By 1994 most trucks should display three digit codes. The key is most, not all. There are exceptions...
So I checked fuse #16 in the main box and it was good. I had my son turn the key on/off several times and could feel the relay trying to actuate, so I'm thinking that is good. Oddly, I removed the battery to have it recharged as we had run it down to where the starter would only click. Upon installing the battery the fuel pump clearly ran for several seconds. We both clearly heard it, but there was no fuel pressure at the schrader valve on the fuel rail. Is there a way to "hot wire" the pump to definitively check it? Could this possibly be a clogged fuel filter? I've had the truck for 7 years and never changed it I'm ashamed to say.
Any ideas at all? Thank you for the help so far!
Yes, jumper Pins 2 & 6 together on the self-test plug.
Here is a photo from Subford
Yes it could be as simple as a plugged fuel filter.
RESOLUTION AT LAST!
But it was not the fuel filter (what a PITA that has become!). After changing the fuel filter still no joy. "Hot wired" the pump again and heard it whirl. Checked fuses and relay again and the relay just felt weak to me. Took a hip-shot chance and replaced the relay and the truck fired up and purred like a kitten!
As an aside I am ashamed that I have neglected that fuel filter all this time. Thanks to all that helped the Growler get back on the road and saved this driver from driving the wife's Malibu everyday!
