86 f250 starter problems help
Old Mar 28, 2014 | 06:14 PM
bluemist14's Avatar
bluemist14
I have a 460 engine stick shift
Old Mar 29, 2014 | 10:09 PM
bluemist14's Avatar
bluemist14
I'm going to check all of the voltage tomorrow. Took starter off and back to autozone and had them test it. It tested good. Looking at the gears on starter closer it looked like some wear on the front section of the teeth. The guys at autozone said they thought we might have a flywheel problem that if the flywheel is worn it would grind the starter teeth. I'm going to look at fly wheel tomorrow. Would these be a possible cause?
Old Mar 29, 2014 | 11:29 PM
Brnfree's Avatar
Brnfree
Unfortunately yes. If there's a bad spot on the flywheel teeth it's kind of like roulette. It'll start just fine for a while, until your flywheel stops at just the wrong place, the damaged spot. Then the gears will clash. I had one of those little blazers with that problem once.
With yours being a manual, if you can get in the habit of parking it on a bit of a slope, in the event you have a problem you cloud let it roll a little and bump the motor with the clutch. That will give you a different spot on the flywheel to try with the starter. That's what I did with the blazer.
I've never heard of anyone filing damaged flywheel teeth without disassembly. I wonder it that's even possible? Hopefully someone who knows more than me will come along.
Otherwise, let's hope it's something simple like wiring.
Old Jan 11, 2023 | 10:21 AM
NotMechanicallyInclined's Avatar
2nd Gear
Ever figure the issue out?
I have the 1986 250 7.5 460 manual. I can’t figure out why my starter doesn’t engage the flywheel. It worked before no problem, then stopped engaging the flywheel. I would rock the truck to roll the flywheel over and then it would engage again.
New flywheel installed with new clutch and flex plate and go to start the truck and the same issue of starter activating but not engaging. The starter is good, it was bench tested at the auto store and I pulled it all the way out and held it myself to see it activate without any issue.
Battery is in proper working condition and I
thoroughly cleaned my grounding to make sure that wasn’t an issue.
Anybody have any advice? As it is, I’m tempted to shim the upper bolt to bring the the starter at an angle to get the bendix to engage the flywheel.
Old Jan 11, 2023 | 04:03 PM
FuzzFace2's Avatar
FuzzFace2
I dont know if this is true with the 460 motor or not but on other motors there is starter for autos and 1 for manual transmissions.
If not you will have to do some measuring.
From the face where the starter bolts up measure from there to the center of the teeth on the flywheel.
Then you have to test to see how far the gear pops out and then measure from the face that mates to the bell housing out to where the gear would be.
The first measurement should match the 2nd one if it is going to work.
You do have the thin metal motor plate on the back of the motor right?
This locates the starter and with out it can cause issues.
Dave ----
Old Jan 11, 2023 | 04:24 PM
2nd Gear
Dave ----
I do have the transmission separator plate for the alignment. When I measured plate to back of flywheel teeth it measured roughly 7/8”. Measuring the distance between the plate to end of armature shaft I got 1 3/16”. This measurement would basically line up on the far side of the flywheel instead of the front side. As far as I know and have seen from searching, none of the parts stores or manufacturers have separate starter motor models for manual or automatic for this truck.
Troy conrad
Jun 23, 2019 11:09 PM
william11
Mar 18, 2016 10:30 AM
LSJUNIPER
Nov 22, 2010 11:39 AM
250kford
1997 - 2003 F150
Jul 12, 2010 12:05 PM
ottawa_dave
Jul 10, 2007 10:04 PM
