Sponsored by: Auxito
starter problem HELP!
Old Jul 6, 2010 | 12:40 PM
250kford's Avatar
250kford
i have a 2000 f-150, went to start this morning and it started fine but the starter kept spinning. turned off the truck and it kept spinning so i disconnected battery cable. this happened twice and now it wont start at all, it clicks and all my gauges jump (which never happened before i dont think). could it be the solenoid or is the starter bad, or something else? is there a way to troubleshoot?
Old Jul 6, 2010 | 05:44 PM
SteevenH's Avatar
SteevenH
Sounds like the bendix wasn't releasing completely. Also if you are now only getting a click then the
solenoid is probably bad or there is not enough battery voltage getting to the starter. Check the
battery voltage also. The motor running will drain the battery if the engine wasn't running.
Old Jul 6, 2010 | 09:40 PM
ottawaguy's Avatar
ottawaguy
Will the bendix keep spinning if the engine is shut off?
This has happened to me, but it was like 20 years ago.
If so, then it does sound like it's time for a new starter.
Old Jul 6, 2010 | 10:13 PM
SteevenH's Avatar
SteevenH
I've seen that happen. If you're sure you have a good battery I would
remove the starter and have it looked at. Autozone can check them I believe. I imagine it's time for a new starter.
Old Jul 12, 2010 | 12:05 PM
loki515's Avatar
loki515
i just posted about this in another thread. check the plastic box mounted under your steering column. it cost me 12$ to replace and stoped burning up starters
rpaxton939
Apr 9, 2014 08:15 PM
spdmpo
35
Dec 24, 2010 09:43 AM
tapout
1997 - 2003 F150
Oct 9, 2006 11:26 AM
mestup
15
Jun 26, 2006 08:27 AM
John Ryan
1997 - 2003 F150
Jan 1, 2003 06:50 PM
