6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 Fuel issues help
Old Mar 24, 2014 | 09:23 PM
mx250racer1's Avatar
mx250racer1
I got 08 6.4 diesel. I drained the diesel fuel out of the HFCM, removed the HFCM manifold cover and cleaned the HFCM. I put the cover back on the HFCM now i have a no start issue. Any ideas what my problem might be?
Old Mar 24, 2014 | 10:44 PM
RM2738's Avatar
RM2738
Air in your fuel. You need to purge the air out. Cycle key on and off a few times before attempting to start. On for a second or two, then off. You'll hear the fuel pump kick on. You may also purge the air from the schrader valve under the hood on the fuel cooler drivers side near the brake fluid reservoir.
Also check the inertia switch on the passenger side behind the access panel to the right of the glovebox on the side of the dash. That has been known to trip.
Old Mar 24, 2014 | 10:55 PM
parkland's Avatar
parkland
I *think* you might have to cycle the key several times to get the fuel circulating again.
Like put it to run, don't start, wait several second, repeat.
Old Mar 25, 2014 | 04:38 AM
bubbasz1's Avatar
bubbasz1
Yep, same as the above, can be a finicky creature after a messing with the HFCM. I believe your supposed to turn on the key for like thirty seconds, turn off, repeat like six times. If still no start go to the fittings on the cooler and purge the air. There are you tube videos on this procedure.
Old Mar 25, 2014 | 06:49 AM
senix's Avatar
senix
The book, if I recall says cycle the key to the on position for at least 6 times.
So turn the key to the on position. Listen for the buzz from the fuel pump. When the buzz shuts off then key off and back on again. 6 times.
If it does not start after that might just check the fuel cutoff switch to see if it popped. Possible but not likely.
Old Mar 26, 2014 | 11:16 AM
mx250racer1
thanks for replies, did the key cycling and purged the fuel system finally got it running
bulletpruf
36
Jun 10, 2023 01:20 AM
jerryprat1
Jul 5, 2018 12:28 PM
snorindad
Aug 10, 2017 04:52 PM
Gertie12
Mar 27, 2017 08:58 PM
blue_16v
Aug 18, 2008 07:44 AM
