Shudder on deceleration
Old Mar 24, 2014 | 03:41 PM
tstone712's Avatar
tstone712
I finally got the truck running great on idle and it accelerates almost perfect with the occasional pinging episode but I cant seem to eliminate the shudder on decel. It seems like its may be the driveling binding or the engine dieing out but i cant tell becuse everytime i try to isolate the cause it dosent do it.
Seems to be eliminated by coasting in neutral.
Truck is a 78 150 4x4 auto. No crazy lift just maybe an inch or 2 in the rear due to over arched leafs.
Let me know what you think.
How many think its joint, trans or engine related.
Old Mar 24, 2014 | 06:13 PM
wyckedcombo17's Avatar
wyckedcombo17
You're not touching the brakes when this happens, right?
I'd check the ujoint at the rear axle. They usually get worn first because they're lower to the ground and get more salt and crud in em. It's 4 bolts to pop it off the pinion yoke and check
Old Mar 24, 2014 | 06:52 PM
MeanGreen460's Avatar
MeanGreen460
Sounds like a u joint problem pull check u joints rear driveshaft>also Make sure pinion yoke is not loose wobbling around
Old Mar 25, 2014 | 09:56 AM
Al T's Avatar
Al T
Sounds like your carrier Bearing.
Old Mar 25, 2014 | 10:16 AM
Filthy Beast's Avatar
Filthy Beast
Another vote for rear U joints. But check them all, both yokes, and trans to engine bolts, as well as T-case bolts.
Old Mar 25, 2014 | 10:22 AM
DeepRoots's Avatar
DeepRoots
Also, if a two piece rear driveshaft, make sure the splines and yoke where the two meet is rust/dirt free and well greased.
If it gets rusty/sticky, it often binds and you'll hear it sometimes on decel, other times it'll pop when you take off from a stop.
Firefighter 1406
Jan 3, 2018 01:56 PM
Jeff64F100CrewCab
Jul 12, 2015 10:48 PM
Papadawg
Nov 13, 2007 08:50 AM
indian_outlaw87
Feb 15, 2005 04:01 PM
rem_243
1978 - 1996 Big Bronco
Jul 30, 2003 11:25 PM
