Trailer Axles Upgrade?
Old Mar 24, 2014 | 10:34 AM
1975FordF250's Avatar
1975FordF250
I'm looking at an old camper trailer frame I want to convert to a car trailer/hauler. Everything is exactly as I want but the axles are 1-3/4 square tube. 1-3/4 diameter round tube is rated at 2000 lbs each so I figured square tube would be about the same. I'm going to usually tow my Honda's which are 2000-2500lbs each, plus the trailer so figure 4000lbs minimum. Those axles would be pushing it.
Is there a way to cut the 1-3/4 tube out and weld in some 2-1/2 tube instead, or is the spindle/hub included in the weight rating? They are drop spindle/axles by the way. Is the axle basically just the brace between each spindle, so by strengthening the axle you allow it to carry more load without breaking?
I plan to reinforce the frame and make decking on it, then have it inspected by the state patrol to make it all legit. I've seen quite a few converted ones and seems like the best option for me.
Old Mar 25, 2014 | 07:49 AM
senix's Avatar
senix
Is there anyway to identify the manufacture of the current axles to verify the weight rating on them?
Old Mar 25, 2014 | 09:51 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Also in most states anything over 2000 lb capacity, needs brakes on trailer.
Old Mar 25, 2014 | 10:00 AM
1975FordF250
They are pretty rusty and I doubt any sticker would be left. I did look up the GVWR and dry weight for a travel trailer that size. A 28 foot travel trailer is about 4500-5000lbs dry weight and 6000 GVWR, so with just a deck on top and some slight reinforcements maybe it might work out for me. If I do get it I plan to shorten the back end slightly to have it as the start of a ramp. I was looking for shorter trailer frame but pickers can't be choosers.
Yes, most camper trailers have electric brakes already installed. I should just have to clean them up.
Old Mar 25, 2014 | 05:53 PM
V10man's Avatar
V10man
Is it tube or is it solid? I bought an old TT frame and it had square solid 4" drop axle on it. The bearings, brakes etc were all parts for a 3500lb axle.
Old Mar 25, 2014 | 08:45 PM
1975FordF250
Not sure, could be solid but just assumed that most are tube. So if it's solid 1-3/4 then likely the weight rating is closer to 3500lbs than 2000lbs?
Old Mar 26, 2014 | 05:05 AM
senix's Avatar
senix
how many lugs are on the tires of these axles?
Old Mar 26, 2014 | 09:42 AM
1975FordF250
I can't quite tell in the pictures, but it looks like 4 lug like most camper trailers I've seen.
My original question was about modifying the axles, so if I wanted to play it safe and replace the 1-3/4 tube with say 2-1/2 tube could I just weld it to the spindle flange? The drum brakes look big so I figure the spindles are beefy too just the axles look a little wimpy.
Old Feb 20, 2016 | 08:59 AM
jetjockey99's Avatar
jetjockey99
4 lug hubs could indicate an axle as light as 1500#'s . The spindles "could" maybe handle more but axles are cheap it would not be worth the effort to try and beef up the originals, just replace them with better axles, I would use a pair of 3500# axles in your case.
Old Feb 1, 2018 | 10:39 PM
Trail_Rider's Avatar
Trail_Rider
You only have to bend one axle once and leave your trailer behind, before you get gunshy of light axles. You are going to end up doing an axle swap so get 7,000 lb axles with brakes and be done with it.
Old Feb 5, 2018 | 09:33 PM
jetjockey99
If it does have 4 lug hubs I would be very surprised if they had even 2K capacity, maybe, but unless you can find the numbers on the axle I wouldn't trust it. Just replacing the center part of the tube will not do what you want, most of the strength in an axle is the spindles and I would not trust the ones you have. Good axles anrn't that expensive and then you will know what you have. Depending on what you may haul in the future, I don't know if you need 7K axles but I would go at least 5K. The other thing to consider is the frames on a lot of lighter travel trailers are not that strong for what you are trying to do, they relied on the trailer box it self to help spread out and absorb some of the weight, without the box the frame may not be strong enough for a car hauler as the frame now has to carry the entire load. I think you would be better off finding a used car hauler.
mongo75
All Things Towing
Dec 29, 2010 02:38 AM
3Mike6
N. California Chapter
May 18, 2008 10:50 PM
FishOnTheBrain
All Things Towing
Sep 6, 2004 02:50 PM
SHESABEAUTY
All Things Towing
Oct 12, 2003 02:03 AM
ford_nut
All Things Towing
Dec 31, 2002 05:59 PM
