Walmart Blue DEF
Old Mar 24, 2014 | 10:21 AM
W7PSK's Avatar
W7PSK
Veteran: Navy
Walmart Blue DEF
My DEF light came on, up till now the dealer had replaced it as part of service. The 30000 they did not. So Ive been researching and found the Walmart Blue DEF.
Good Bad Ok for use in our trucks ?
Old Mar 24, 2014 | 10:39 AM
720Deere's Avatar
720Deere
I have not been able to find any evidence to the contrary of my believe that DEF is DEF no matter the brand. It isn't a critical fluid like coolant, motor oil or diesel fuel so it is pretty hard to screw up. After all, the major component of DEF is water.
Old Mar 24, 2014 | 11:14 AM
BlackBeest's Avatar
BlackBeest
Originally Posted by 720Deere
I have been unable to find any evidence to the contrary of my believe that DEF is DEF no matter the brand. It isn't a critical fluid like coolant, motor oil or diesel fuel so it is pretty hard to screw up. After all, the major component of DEF is water.
Fixed that for ya
Old Mar 24, 2014 | 11:20 AM
Hdslider's Avatar
Hdslider
It will be just fine. If you have a large fuel center. Alot have it at the pump. Alot cheaper as well.
Old Mar 24, 2014 | 11:50 AM
720Deere's Avatar
720Deere
Originally Posted by BlackBeest
Fixed that for ya
Thanks, Chuck! I missed the "NOT" that I intended to be there. Sometimes the mind and the fingers just aren't in sync!
Old Mar 24, 2014 | 12:45 PM
jdadamsjr's Avatar
jdadamsjr
As stated - MOST truck stops carry it now and usually around the $2.80 / gal cost
Old Mar 24, 2014 | 12:58 PM
Iowa Ford's Avatar
Iowa Ford
Hope this helps.
<cite class="_md">https://www.fcsdchemicalsandlubricants.com/.../DEF%20Shelf%20Life%...</cite>‎
November 7, 2013. To: All Ford and Lincoln Dealers. Subject: Conditions affecting Diesel Exhaust Fluid (DEF) Shelf Life and Fluid Quality. Diesel Exhaust Fluid ...
Old Mar 24, 2014 | 01:04 PM
senix's Avatar
senix
I am running the walmark blue def right now.
The ford fill spout fits it too btw..so no mess and it will still stop filling when full.
Old Mar 24, 2014 | 02:17 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I have never bought any DEF in a jug, always buy at the truck stop, about 1/4 to 1/3 the price per gallon.
Old Mar 24, 2014 | 05:51 PM
Tom's Avatar
Tom
Wal-Mart doesn't make or sell DEF. It's a Peak product, and it's sold in auto parts stores, big box retailers, truck stops, and just about everywhere else that would possibly sell DEF.
This stuff meets the ISO standard for DEF, and I've never heard of an issue with it. My last DEF fill was with this stuff before I sold the truck.
Old Mar 24, 2014 | 06:04 PM
RWC2504's Avatar
RWC2504
I've used Peak Blue DEF with no issues. I like that it comes in one gallon containers so its easy to take a gallon on a long trip just incase the warning light comes on along the way. Keep a couple empty containers and fill at the local truck stop and save some $.
Old Mar 24, 2014 | 07:17 PM
kper05's Avatar
kper05
I have also used Peak BlueDEF since the factory fill was used; 56k miles.
Old Mar 24, 2014 | 07:24 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
DEF fluid is DEF fluid, all the same.
Just way cheaper in bulk from the pump.
There's even one truck stop along one of my routes that sells it for $2.19 a gallon.
Keep swearing that I am going to get a drum and fill it there and keep it at the house but then never get around to it.
Old Mar 24, 2014 | 07:34 PM
720Deere's Avatar
720Deere
I wouldn't recommend buying such a large quantity. For as long as it takes to use 5 gallons, you would be long beyond the expected shelf life before you used more than half of a drum. Filling the truck at the bulk pump as well as a pair of 2.5 gal jugs would be at least 3-4 months supply for most people.
Old Mar 24, 2014 | 07:53 PM
twfish's Avatar
twfish
Why everyone is on the topic isnt it possible to just keep filtered through it and not have any effect?
