302 sb build?
Old Mar 23, 2014 | 08:50 PM
ford_0004's Avatar
ford_0004
302 sb build?
I've got a 302 and was looking to go threw it. I was told I could swap out my stock heads for 400m heads with a special intake for more power . Is there any truth to this . I was thinking they were different all together.
Old Mar 23, 2014 | 09:21 PM
Conanski's Avatar
Conanski
There are more heads made for the small block windsors motors than all other Ford motors put together so you don't need some odd ball combination to get more power.
Old Mar 23, 2014 | 11:02 PM
Beechkid's Avatar
Beechkid
Completely agree....also the 400M series heads (IIRR) would lower your CR (just a tad) and reduce flow at 4000+ rpm.
Old Mar 24, 2014 | 12:02 AM
85e150's Avatar
85e150
Whoever told you that should not be relied upon for any information, up to and including whether it's day or night.
Old Mar 24, 2014 | 04:53 AM
ford_0004's Avatar
ford_0004
That was my thought but was just checking. My dad has an old mercury montego with a 351w that would possibly go to scrap and use the crank , heads and possibly the rods .
Old Mar 24, 2014 | 03:43 PM
KIDkiser's Avatar
KIDkiser
I have been through this many times,forget the 302 ,and build the 351.besides it's the 351 Cleveland you use the heads off of,but it way more trouble than its worth.i have seen quiet a few windsors with a cheap 393 stroker kit make some impressive HP with stock heads.
Old Mar 24, 2014 | 04:07 PM
85e150's Avatar
85e150
Use the whole thing.
351W crank will not work in a 302.
Heads may or may not be better.
But, starting with a 351W you will be miles ahead in torque and power vs. a 302 with similar mods.
Old Mar 24, 2014 | 10:16 PM
jimbbski's Avatar
jimbbski
I think what you should do is post more info. Say what year the engine is? What vehicle will in go in to? How will it be used? Pure street, or something else? What is your budget?
Old Mar 29, 2014 | 06:59 AM
78fordman's Avatar
78fordman
You can. Some mods have to be done to the heads. It takes a special head gaskets from ford and edelbrock makes an intake that will adapt the whole deal. The head mods have to do with the dry to wet intake.
You also need special pistons with the reliefs cut in a different spot. Kb makes these too. I have a bunch of info on this somewhere. I will see if I can dig it out.
Sent from my leash using IB AutoGroup
1bad67sbf
24
Apr 11, 2010 01:45 PM
0351mike
1966 - 1977 Early Broncos
Apr 23, 2009 11:58 AM
BOSSv10
Sep 30, 2006 01:33 AM
BIG-COUNTRY
Dec 6, 2005 08:21 AM
Bob Chan
Jun 10, 2004 12:25 PM
