292 Manuel conversion to automatic?
Old Mar 23, 2014 | 07:50 PM
halltm's Avatar
halltm
I have a F100 that I want to convert to automatic. What do I need and how complicated is this to do? I keep hearing about ford o matics
Thanks
Old Mar 24, 2014 | 09:09 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
You can convert to a C4 using Flat-O Products. It's all you need except tranny, linkages, cooler & lines. It's pretty straight forward. Gear Star also makes a adapter that will adapt almost any Ford small block tranny to a Y-Block....
Keep us posted on what you decide.
Old Mar 24, 2014 | 10:01 AM
Y-Blockhead's Avatar
Y-Blockhead
I wouldn't fool with the Ford-o unless you want your Truck to be "original". Too many more "modern" Automajics out there. The Ford-o can be upgraded to a FMX but I would suggest a Flat-o/C-4 or if you want OD go with the AOD.
Check out Bendtsen's for transmission adaptors also.
Old Apr 9, 2014 | 01:57 PM
HT32BSX115's Avatar
HT32BSX115
That's the one I have to bolt my E4OD to.
It's a bit expensive but it fits!
'86 F150
34
Aug 3, 2015 09:09 AM
TJ62
13
Nov 30, 2014 09:29 AM
vbarker
Feb 3, 2008 10:25 PM
preppypyro
Nov 5, 2007 11:29 PM
300sixowner
Aug 6, 2004 03:46 PM
