Tranny Options
Old Nov 4, 2007 | 11:00 PM
preppypyro's Avatar
preppypyro
Tranny Options
So I picked up a nice little early nineties regular cab shortbox 2 wheel drive. The tranny is screwed in it, and it came with a replacement AOD.
Now i have researched and i see the AOD tranny is a weaker tranny. Do i have options at all to beef it up, or replace it with a better tranny? Would I have to mess with the computer at all?
Old Nov 4, 2007 | 11:06 PM
85e150's Avatar
85e150
Beef it up. Options are a Chevy trans via an adaptor (maybe depending on your engine) or a 3 speed or a more expensive 4 speed OD.
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
http://ckperformance.com/ford_aod.html
Try this one first, they quote prices on the site. Not your $100 junkyard trans....
http://www.tciauto.com/Products/Ford/ford_aod.asp
And if you have an AOD E, then yes, your computer will wander about looking for it if you install an old FMX or C4....
Old Nov 5, 2007 | 08:55 PM
preppypyro's Avatar
preppypyro
Sweet thanks for the links. I would like to keep it an overdrive if possible too.
Old Nov 5, 2007 | 09:24 PM
17fordguy's Avatar
17fordguy
i bleive there is also another one out of the 250 that is a much stronger trans
Old Nov 5, 2007 | 11:29 PM
85e150's Avatar
85e150
One of the links talks about using 4R70W parts in the AOD to beef it up, including lower 1st and 2nd gear.
Besides the 4R70w, you might also be thinking of the E4OD. That is a beast of a trans and requires a controller. No need to go there for this application.
1960fordf350
Sep 30, 2012 04:17 PM
ryans428
May 28, 2005 10:19 AM
