Ford-A-Matic vs C4
Old Feb 3, 2008 | 08:31 PM
vbarker's Avatar
vbarker
Ford-A-Matic vs C4
I just acquired a 58 F100. It has a Y-Block 292 with a Ford-A-Matic. Is this Tranny worth rebuilding, or can a C4 be fitted to the Y-Block with out a lot of work and expense. Thanks in advance
Old Feb 3, 2008 | 09:30 PM
85e150's Avatar
85e150
C4 would require an adaptor, but Advanced Adaptors lists nothing for the y block. The only adaptor I see is for the AOD. $750 and you need a reworked AOD, which they do not provide for free.
http://www.transmissioncenter.net/AOD.htm
Scroll down just over half way.
As for the Ford o matic overhaul, I googled "ford o matic rebuild kit" and got:
http://www.autotran.us/fmkits1.html
http://www.transmissionsbygene.com/
And a host of others. If it's a 3 speed Ford o, I'd check out the the rebuild.
Old Feb 3, 2008 | 10:25 PM
vbarker's Avatar
vbarker
85E,,, Thanks for the good info, I'll check them out.
69taposer
Jul 3, 2012 12:59 AM
Snowking
Mar 25, 2007 08:06 PM
dirtfarmer
Dec 26, 2002 05:10 PM
Jeff Doersom
Oct 28, 1999 03:40 PM
