Squeeling bellows pipe.
Old Mar 22, 2014 | 09:15 PM
steelhead2's Avatar
steelhead2
So, at about 8lbs of boost i get a squeeling from the turbo area. Tore turbo down, inspected , all looked fine. Screwed around for to long and said to myself " this sounds just like a blown bellows on a cummins isx" (insert light bulb here). So, can i just replace the bellows or is it attached to the whole y pipe?.
Old Mar 22, 2014 | 11:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You have the Y-Pipe and then the EGR up-pipe...
Josh
Old Mar 23, 2014 | 09:22 AM
steelhead2's Avatar
steelhead2
Is this an aftermarket set up?. Whats this going to run me?.
Old Mar 23, 2014 | 09:25 AM
Bullitt390's Avatar
Bullitt390
You sure the Y-Pipe is leaking?
Send me a PM and I'll help you out.
Josh
Old Mar 23, 2014 | 10:06 AM
steelhead2's Avatar
steelhead2
Hi josh, i can hear a faint hiss with it idling. Then once it hits 8lbs of boost or so is when it starts whistling. Boost is good, power is good to. Tore turbo diwn and it looked good. Its definitely squeeling behind the turbo.
Old Mar 23, 2014 | 10:07 AM
steelhead2's Avatar
steelhead2
That was suppose to be a pm!
Old Mar 23, 2014 | 06:49 PM
Bullitt390's Avatar
Bullitt390
You PM Inbox is full...
On used pipes I'll use an LED flashlight in the dark to find pesky leaks.
Sure the y-pipe is aligned with the turbo?
Josh
Old Mar 23, 2014 | 08:22 PM
Yahiko's Avatar
Yahiko
Look for soot tracks.
Sean
P.S. Speaking of PM's. Josh did you get that last one I sent?
Old Mar 23, 2014 | 08:57 PM
steelhead2's Avatar
steelhead2
Sean
It just started yesterday. I dont think id see any yet. Just drove it almost a hundred miles squeeling like crazy. If it were a turbo i think it wouldve been turned into shrapnel. 8lbs of boost is the magic number it starts at.
Old Mar 25, 2014 | 01:38 PM
steelhead2's Avatar
steelhead2
I was able to put 50psi to the y pipe and got no leakage from the bellows. Thought for sure that was it. Has anyone ever had the o ring on the compressor side of the turbo that seals the housing fail?. Ive got all new gaskets for the exhaust coming, along with that o ring. Ill double check cac boots and stuff, but they looked fine.
Old Mar 25, 2014 | 01:57 PM
Rusty Axlerod's Avatar
Rusty Axlerod
If you have the plastic cold side CAC pipe, pull the air filter and check the corrugated section. Sound a lot like what my truck did. In the pic I'm bending it down so it flexes open, it was very hard to see with the pipe in the truck. Two splits and a small crack in the pic.
Old Mar 25, 2014 | 02:42 PM
steelhead2's Avatar
steelhead2
Mines aluminum from the cooler to intake. Doesnt sound like boost, but an exhaust leak. My patience is wearing thin with the 'ol girl.
Old Mar 25, 2014 | 02:51 PM
Bullitt390's Avatar
Bullitt390
I take it you removed the y-pipe and plugged all 3 ends and applied shop air to one of the plugs?
Josh
Old Mar 25, 2014 | 02:52 PM
Per4mance's Avatar
Per4mance
Get somebody to power brake it with the hood open and look in there(be VERY careful) you'll find it
Old Mar 25, 2014 | 03:30 PM
steelhead2's Avatar
steelhead2
I tried that to. Sounded like it was coming from the turbo, or the general area. Tore the turbo down and it looked fine. Thats what led me to believe it was a bellows pipe. 8lbs of boost is the magical number it whistles at.
