What a bummer!!!
Old 03-22-2014, 07:49 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
What a bummer!!!
This truck passed the bubble test btw.
This one is kinda outta focus.
Running a compression test now
Old 03-22-2014, 08:10 PM
jmtbiggin's Avatar
jmtbiggin
jmtbiggin is offline
That is outta of my league,fingers crossed anyway
Old 03-22-2014, 08:15 PM
run6.0run's Avatar
run6.0run
Just a bit about cac clamp placement. This truck came from a speciality shop also. Really don't want to sling mud,, but little stuff like this shouldn't come out of "speciality shops".
Old 03-22-2014, 09:00 PM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
6.0 powerstroke cac clamp placement - YouTube
unfortunately, stuff like tat can be overlooked. just 5 more mins to triple-check everything makes a huge difference.
when my dumb a** installed the new intake elbow and updated cold side CAC tube recently, i got everything back in and nice and snug but i forgot tat i unhooked the degas bottle return line.
dang, did tat coolant spew out. lol.it looked like my truck just blew her heart valve from a clogged artery. maybe a cheeseburger got stuck in there. lol.
i can't wish my ex-wife got stuck in there, cos it would cause catastrophic failure again and i'd be the first suspect.
Old 03-22-2014, 10:26 PM
run6.0run's Avatar
run6.0run
That's funny Dom,,
Yeah,, I understand anything can be overlooked.
Here's a bunch of videos leading up to pulling the engine.
What do you guys think this stuff is on the injector?
Pulling the engine tomorrow.
Btw,, Corey is here and we are gonna swap his engine too. Finally gonna get that Blackwater one out of there.
Old 03-22-2014, 11:29 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Not going to try another injector? Possible it wasn't torqued to spec along with whatever that plastic is?
Maybe a plastic wire brush was used to clean the injector cup and left some bristles?
Josh
Old 03-22-2014, 11:36 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Could the injector Blew a Hole in piston
Guess I better wach rest Videos LOL
We Would Like to see a Slight Vac Pressure at the OIL Filler Cap
Old 03-23-2014, 01:42 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
That looks like it going to be a bummer.
Green coolant !
BTW I have some info on the streaming question.
Looks the easy way is a standalone PC and use a PCI-Express
card with HDMI IN. The price is all over the place. Depends on
what you need the card to do.
Do you have an injector sleeve compression tester? that would
let you know if that plastic stuff was letting gasses past the O-rings
and that it's not the bottom end. I guess if you don't you could clean
the sleeve and install a fresh set of O-rings and retest that low cylinder.
Then if it jumps back up you know it was a bad cleaning job and not the
bottom end taking a dump.
Sean
Old 03-23-2014, 01:47 AM
run6.0run's Avatar
run6.0run
You have my guess Benny. I am thinking the piston has a hole in it. Mostly due to how the engine runs right now. I am doubting there is any damage to the block. I am actually considering making a new purchase. Snap on has a very cool new setup. I gotta check my bank acct. lol. I will definitely let you all know about it when it crosses the threshold.
I don't feel there's gonna be any good news come out of just an injector Josh. It passed the bubble test,, and I cranked it with the oil rail removed. I was "pipe dreaming" that maybe a valve was leaking up top,, or possibly a multiple failure on that #8 Inj. Very unlikely,, but maybe that Inj was venting compression and all that compression was exiting through the fuel orings???? No dice on that shot n the dark. Lol. It's blowing outta everywhere that the crankcase has access to. This is a hard working truck,, I am believing that #8 was throwing a bit too much fuel. Maybe this truck should bet first install of ceramic coated pistons???? That'd b cool. I have been considering ceramic coating my pistons. It is about 1500 extra for it,,,(not exactly sure on that yet) Not sure if that's on the table for this build tho.
Old 03-23-2014, 01:54 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Well that answers that.
I did not know you cranked it with the injector in place and
did not get the blow by.
Sean
Old 03-23-2014, 08:06 AM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Anthony, Got the dear John on sending you Reps, but wanted to say thanks for the videos. They are very helpful and much appreciated!
Old 03-23-2014, 08:07 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
Well if it is as you suspect a hole in #8 the actual compression test will verify as well as you should get an audible chuffing noise from the crank case, may be hard to hear and require several revoloutions of the engine.
Old 03-23-2014, 08:43 AM
Bullitt390's Avatar
Bullitt390
Missed the part about the bubble test.
That's a bummer the shop destroyed that engine.
Josh
Old 03-23-2014, 08:44 AM
cheezit's Avatar
cheezit
cheezit is offline
Snap on makes a bore scope with a camera that will go down a glowplug hole
Old 03-23-2014, 08:59 AM
Per4mance's Avatar
Per4mance
Per4mance is offline
I have that bore scope ,but it's one of the first ones.Ant make sure you get the color one that can download the pictures to a laptop or printer
Quick Reply: What a bummer!!!
