Newb from Ky
Old Mar 22, 2014 | 01:23 PM
dhurt's Avatar
dhurt
Newb from Ky
New guy here and I have a question for you guys. I was wondering if someone would decode my tag for me? I just got this truck yesterday, and am pretty excited about it.
Serial number-F10OD301347
Color-TM
Trans-A
Axle-11
DSO-61
Thanks
Old Mar 22, 2014 | 04:40 PM
SuperSabre's Avatar
SuperSabre
Welcome to FTE. I will try your decode for you. If I'm erroneous, Number Dummy or someone else will fix it. F10 = F100 2 wheel drive truck. The first letter code denotes your engine, but "O" is not a correct code. Either you've misread it or the factory misstamped your plate. Your choices are: A = 223 cubic inch 1 bbl I-6, B = 262 cubic inch 1 bbl I-6, C = 292 cubic inch 2 bbl Y block V-8, or D = 292 cubic inch 4 bbl Y block V-8. The next letter, "D", indicates Dallas, TX for a build plant. 301347 = built in June, 1962. Color TM = two tone paint with T = Sandshell Beige and M = Corinthian White. Trans A = 3 speed manual. Axle 11 = 3.70 gears in a Ford 9 inch non-limited slip differential. DSO 61 = ordered from the Dallas district sales office. Your truck was not a special order vehicle. Hope this helps. Enjoy your new truck.
Old Mar 22, 2014 | 06:50 PM
dhurt's Avatar
dhurt
Thanks Sabre! I rechecked the engine code and it was a C. I'll post some pics before too long. Thanks again
ssyeller
Feb 7, 2016 03:46 PM
tylers60s
Jul 14, 2015 11:48 PM
mont974x4
Aug 27, 2013 01:02 PM
markzieglerinsd
May 25, 2011 02:44 AM
walunsf
Jun 4, 2004 12:39 AM
