2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Gate Opener limited range
Old Mar 21, 2014 | 11:24 AM
Henry Ford the 8th's Avatar
Henry Ford the 8th
Anyone know how to improve the range of the visor mounted rolling code door & gate opener in a 2013 Expedition? I have to pull up until the truck almost touches the gate to get within range, but the transmitter that came with the gate works from 100 yards away. Is there some way to increase the power of the factory unit? it is convenient but pitifully weak. The owners' manual even suggests lowering the visor to eliminate interference from the truck roof!
Old Mar 21, 2014 | 11:41 AM
berry1234's Avatar
berry1234
Something is wrong. Mine in my 08 works from about 100 yards away.
Try reprograming another button.
Old Mar 22, 2014 | 08:34 AM
Henry Ford the 8th
Berry1234, is your unit a Lear "Car2U" type? Not sure what year models use what unit. Tech help at Lear told me to put a better antenna on my gate. similar range issues with other button on garage door. Seems like the only variable is the output power of the remotes. I remember having larger output transistors installed to increase the power of CB radios. Maybe something similar can be done?
Old Mar 22, 2014 | 06:53 PM
GITanker's Avatar
GITanker
I also have a 2013 Expedition and it has the Home Link remote system in the visor. I have found out that my garage door range on the visor is under 100 feet, give or take 10 ft. Keep us informed as I would also like to extend the range on the remote in the visor.
Old Mar 23, 2014 | 05:09 PM
BlueTruc's Avatar
BlueTruc
Lear 2 U had to have a company install another receiver in my control box because the in visor remote would not program to the original control moduel. After all that my 2011 Expedition EL XLT has the same limited range that you are experiencing. The wife doesn't even use the visor controller because she has to be almost in the swing path of the gate for the visor remote to work. Haven't gone back to Lear 2 u but based on what I am hearing it may not be worth any more of my time either.
Old Mar 24, 2014 | 04:22 PM
berry1234's Avatar
berry1234
Mine is Home Link.
Old Apr 12, 2014 | 09:15 PM
Henry Ford the 8th
So I gather from this and other threads that some Expeditions are equipped with Lear Car2U visors (like mine) and some have Homelink. Are both of them compatible with dip-switch servos like my Viking gate opener? If the Homelink is more powerful for $400, it might fix the problem. My only question is does it come with babyseat airbag warnings en Francais? Just in case I have a *&%$@ french baby? Because you can't be too careful even if it means hideously defacing the interior of a $50,000 truck?!! If it comes without those stickers it would be worth $400 even if it didn't open the gate at all!
Old Apr 16, 2014 | 10:29 AM
berry1234's Avatar
berry1234
Another option is to get a homelink visor from some other/older car/truck on ebay, pull the parts out and wire it yourself. I have seen others do this. They can be had for cheap.
Old Oct 12, 2014 | 04:37 PM
Henry Ford the 8th
some new info
OK, Mrs. just got a 2015 Subaru Outback. It has Homelink unit in the visor. I programmed it to the gate and it works from est. 150 ft. away. So I should find out what the Homelink transmitter for the Expedition looks like and see if I can install it in my visor in place of the inferior, underpowered Lear unit. Rather disappointing, every time I drive in or out.
Old Oct 15, 2014 | 09:02 AM
rayofsi's Avatar
rayofsi
hah my 2015 forester works 10x better then the opener in my 2011 expedition!
jonrjen
6.7L Power Stroke Diesel
25
Jul 22, 2015 07:21 AM
Ford20141959
Jan 14, 2014 08:24 AM
jimrutter
Feb 20, 2013 01:18 PM
himmelberg
Jun 8, 2006 10:26 PM
jamesg
Dec 15, 2002 07:10 AM
