4.0l howling noise
Old Jul 2, 2003 | 04:05 PM
ka1cu's Avatar
ka1cu
4.0l howling noise
hi guys my 97 ranger with a 4.0l engine intermittently howls sounds like it from the plenum area...only happens when outside temp is over 80 degrees and ideling or low rpm...any thoughts would be appreciated
Old Jul 4, 2003 | 06:49 AM
Rockledge's Avatar
Rockledge
4.0l howling noise
You might try looking through these threads from the Ranger Forum:
Ranger 4.0L Noise1
Ranger 4.0L Noise2
Old Jul 4, 2003 | 10:54 PM
samhihn's Avatar
samhihn
4.0l howling noise
Check all your vacuum hoses too. Using a sthoscope or a length of hose held to your ear you may be able to isolate the noise fairly quickly. best of luck......
Old Jul 6, 2003 | 09:42 AM
ka1cu's Avatar
ka1cu
4.0l howling noise
Thanks rockledge.....pulled off the iac cleaned it with a typewriter cleaner / degreaser sprayed some wd-40 on it and drove all day yeasterday in 95 deg. no more noise... thanks and have a good day
Old Jul 6, 2003 | 10:47 AM
Rockledge's Avatar
Rockledge
4.0l howling noise
Thanks for the feedback...always like to hear those success stories....you are lucky to get away with just a cleaning of the IAC, most people have to spend the dough for a new one!
Old Jul 8, 2003 | 10:06 PM
prodigy's Avatar
prodigy
4.0l howling noise
My 95 with 4.0V6 makes the same sound but i just figured it was the whirling sound of the fan. Never figured it was a mechanical problem. What exactly does this little dohicky do. And besides the noise is there anything else it can mess up. THanks
ggwash21
2004 - 2008 F150
Jan 17, 2009 02:38 PM
WuShock
Nov 1, 2006 07:48 AM
MallardMagnet
1983 - 2012 Ranger & B-Series
Feb 7, 2004 01:06 AM
Ultramagdan
Modular V8 (4.6L, 5.4L)
Jun 12, 2003 07:19 PM
