AOD upgrades?
Old Mar 20, 2014 | 01:29 AM
351Cleveland C4's Avatar
351Cleveland C4
AOD upgrades?
I got an AOD that's gonna be going behind my mild 351C in my 71 F100.
So I want to know, what are some things I should do (if any) before I put it in.
I want to do a good shift kit, a heavy duty/ towing kind, not a hot rod kind.
Any other good upgrades for strength and performance?
Old Mar 20, 2014 | 01:37 AM
351Cleveland C4
Oh yea, is there a good heavy duty truck style TC available? All the ones I find are for street / strip/ racing mustangs.
Old Apr 23, 2014 | 02:33 PM
351Cleveland C4
Oh come on now, I know some of you have rebuilt/ upgraded your trannys. What did you use and what did you do?
Old Apr 23, 2014 | 03:06 PM
Conanski's Avatar
Conanski
Everything you will probably need can be found here.. Ford-AOD.com the ultimate AOD Transmission Perfromance Website
Talk to them and tell them what year your trans is and they can then suggest upgrades. Early AODs were pretty weak compared to later versions which got bigger drums with more clutches, wider bands, and better quality parts overall. The concentric input shaft is a known weak point so you should upgrade it or consider eliminating it completely if you can live without the lockup feature, however if you plan to tow with the truck I suggest not deleting it as a constantly slipping TC generates a lot of heat and obviously hurts gas milage. It is also possible to install the 4R70w wide ratio gear set in some AODs so maybe look at that as well.
Old Apr 23, 2014 | 03:30 PM
351Cleveland C4
SWEET! That's an awesome site! Thanks again, Con!
Hitokori
Dec 4, 2009 05:53 PM
currituckF150
Jun 23, 2008 04:51 PM
floss67
16
Apr 19, 2005 06:20 AM
Stokes
Jul 15, 2003 03:32 PM
fishintruck
Jul 15, 2002 11:54 PM
