Wheel Installation
Old Mar 19, 2014 | 01:29 PM
Tedster9's Avatar
Tedster9
Reading my 64 Ford shop manual, part 3-4 , for wheel installation it sez:
"For proper balance, line up the notch on the drum with the valve stem on the wheel."
Gotta admit, didn't know this. Getting ready to put wheels on - and didn't notice any notch on drum. There are two machined holes on either side of one of the wheel studs, maybe the stem/wheel is indexed to this?
I found the valve stem on the tire, so we're good there. Anybody know?
Sent from my iPhone using IB AutoGroup
Old Mar 19, 2014 | 05:31 PM
jowilker's Avatar
jowilker
Written well before modern balancing techs used today. Don't worry about it.
John
Old Mar 19, 2014 | 07:15 PM
Tedster9's Avatar
Tedster9
Yes, tires are balanced a lot better on wheels, but apparently there was some thought given to a rough balance of the wheel/tire and the drum, as an assembly.. Jus' Sayin'.
It won't hurt anything to follow the manual here, anyone know where the notch is on the drum?
Old Mar 19, 2014 | 08:03 PM
schoo's Avatar
schoo
Was that with tube or tubeless tires the notch thing I mean or both
Old Mar 19, 2014 | 08:24 PM
Tedster9's Avatar
Tedster9
When I plugged the quote into search engine the same verbiage was found in a 70s shop manual repro teaser, so it was around a long time.
Old Mar 19, 2014 | 10:43 PM
37 Ford guy's Avatar
37 Ford guy
Well, after 50 years of wear, tear & parts swapping, it's not going to make 2 cents worth of difference in my opinion. If you're that concerned about it, have the tires spun balanced on the truck. Otherwise, just bolt them on and drive it! It's not a Lamborgini......
Old Mar 19, 2014 | 11:02 PM
Tedster9's Avatar
Tedster9
Ya sure, just wondered if anybody knew.
Old Mar 19, 2014 | 11:29 PM
TxStang2010's Avatar
TxStang2010
I have seen rear drums with a notch before on 70's F series 3/4 and 1 ton trucks we had where I worked , it allowed clearance for dual rear tire setups on the inner wheel for the angled brass valve stem to turn and point outward being they had so much backspacing . If you didn't line them up you would break off the brass valve stems .
j4henry
Jul 24, 2011 10:12 AM
teppler
Sep 16, 2010 03:51 PM
thedaddycat
Nov 27, 2006 08:51 AM
ona6day
17
May 29, 2006 05:51 AM
