Accelerator Pedal Assembly
Old Mar 19, 2014 | 12:24 AM
glovemeister's Avatar
glovemeister
Hey guys,
Just wondering if you can look down at your pedal assembly for me and tell me how many wires are on your connector?
It should be ten slots in the TPS connector.
My hunch is adjustable pedal trucks use all 10 slots, and non adjustable trucks use 5 slots.
Also please post up your year if you can.
If anyone has a schematic for the TPS harness on these trucks wouldn't mind getting that either.
Thanks
Old Mar 19, 2014 | 05:50 AM
bulla's Avatar
bulla
This info was just shared with me yesterday.
from a thread Pop posted in....
If it were mine, I'd pop it out (it's only three small nuts that hold it in). That way you can use a DVM to see if the switch is electrically operational, whether you can hear it or not.
Here's a schematic of the wiring for the IVS part of the truck:
http://www.e-toolbox.com/ads/wiring/va137402.pdf
and here's the accelerator pedal position sensor part:
http://www.e-toolbox.com/ads/wiring/va137404.pdf
What you're looking for is at the bottom of each of those pages.
These diagrams are for what's called "early production", and "late production" are the ones with a single plug instead of two, but the WIRE COLORS are the same in both cases, so test the IVS by reading the continuity between the pins that are attached to the RED/LT GRN and RED/YEL wires.
Here is the diagram for "late"
http://www.e-toolbox.com/ads/wiring/va163297.pdf
The IVS should read "closed" at the idle position only.
Old Mar 19, 2014 | 05:53 AM
bulla's Avatar
bulla
Supposedly you can adjust the obs pedal assembly. Not sure about the super duty, but I can safely say there are no adjustments on my '01 .
Old Mar 19, 2014 | 01:13 PM
glovemeister
Appreciate those detailed diagrams bud, not sure how I managed to never find those!
Perfect for what I need.
Thanks again
Old Jun 27, 2014 | 12:55 AM
glovemeister
Bump still need pin number.
Looking specifically at the single connector trucks.
I've seen some with ten pins, but they are fixed pedal so I am not sure where they go to. Also trying to track down part numbers, to order one. Ordering by description doesn't seem the best.
Any info on Dorman v. OEM pedal assemblies?
Old Jul 2, 2014 | 01:23 PM
glovemeister
Appears the Dorman has 5 terminals.Standard Motor Products has 10. Looking at the connectors/pigtails though they are listed as 9-10 terminals, which is weird. Wonder why the discrepancy for the same extra vehicle?
Old Jul 9, 2014 | 03:16 PM
glovemeister
Bump.
Still been looking for the correct 5 terminal connector.
All I am finding is 3, and 9-10.
Any one snag a part number off your connector, or a picture to see is the 9-10 is the same and just has wires for more than one vehicle.
Thanks
Old Jul 9, 2014 | 10:06 PM
FiznUKa's Avatar
FiznUKa
Maybe I missed something here but what year is your truck?
Old Apr 25, 2024 | 06:29 AM
MojoGoJo's Avatar
MojoGoJo
2nd Gear
Throttle position sensor with adjustable pedals connector issues
Loading...
Loading...
hello I am having trouble finding the right connector for my truck and these diagrams would probably really help but the links you posted are no longer valid. Here’s my issue, I have a 02 excursion 7.3 with the adjustable pedals. The connector that goes to the assembly in my truck has only 5 wires coming out of the back and the only connector I can find is ford Wpt1326 which looks very similar but has 10 wires. I have a parts excursion but it has the 6.0 and I took the connector but it’s gray instead of black and has 9 wires coming out the back of it . Can i just get that one and only connect the wires that come from the harness of the 7.3 truck will it work ? Please help here are pictures for reference picture #1 is the original connector in the 7.3 truck (the one in need ) and picture 2 is the one I removed from the 6.0 truck
Old Apr 25, 2024 | 12:10 PM
John in OkieLand's Avatar
John in OkieLand
if the connector will physcially fit properly,
YES,
go wire to wire no matter the color, follow the wire scheme of the OEM part you are placing, so that it goes into the proper pin hole in the 6.0 connector.
leave the extra holes empty, to prevent confusion in the future.
you probably do not have a MOLEX pin extractor?
they are hollow and you push them into the socket from the opposite side of the wires, it depresses the locking tab, and you can slide the pin out, makes it super easy to use a "new" blank connector.
saving you don't have that, cut the 6.0 wires, and splice to the 7.3 wires.
Old Apr 25, 2024 | 09:29 PM
udsuth78's Avatar
udsuth78
X2. If the connectors mate correctly and the physical pins are right then the rest is irrelevant. There are various pin removal tool sets on Amazon. I can't say whether one is better than another or if any of them work. Only that I have seen them. I typically just make a tiny flat pick by hammering the end of a paper clip then shaping to suit with a file or whatever is handy. It usually works for me.
Old Apr 26, 2024 | 11:15 PM
Socket's Avatar
Socket
I’ve found a screw driver kit like this works well for depinning connectors. I’ve used it on the Ford ones with good luck, plus it’s multifunctional.
Uzumati
Apr 3, 2019 09:04 PM
amccabe1
May 6, 2015 10:24 AM
Dan V
Mar 25, 2014 06:13 PM
Iasphynx
Feb 28, 2013 08:08 PM
WonderDonkey
Sep 25, 2007 06:43 PM
