roller rocker adjustments??
Old Jul 2, 2003 | 11:26 AM
ranger429's Avatar
ranger429
i just got the motor all done and it seems that the roller rockers do not stay lined up with the top of the valve?? i have not started the motor yet but i just want to be sure before i break something. the lash is set a zero on all and i am afraid to run it in fear that the rockers don't stay lined up. should i tighten the rockers up a little more? they are set right now to where you can just spin the push rod. thanks and any help is appreciated.
Old Jul 2, 2003 | 11:37 AM
LxMan1's Avatar
LxMan1
Does this motor require guide plates to keep the pushrods aligned?
Old Jul 2, 2003 | 12:55 PM
ranger429's Avatar
ranger429
that is a good question,how do i know? there were no guide plates with the original rocker. they are dove heads
Old Jul 2, 2003 | 01:48 PM
georgedavila's Avatar
georgedavila
DOVE heads originally had rail rocker arms to keep the pushrods in alignment. You need pudhrod guideplates and hardened pushrods to run roller rockers.
Old Jul 2, 2003 | 02:12 PM
ranger429's Avatar
ranger429
ok thanks for the reply, will the guideplates fit inside ford motorsport valve covers?
Old Jul 2, 2003 | 04:25 PM
airharley's Avatar
airharley
You have so much room in those you can run rocker stud girdles. I have my roller rocker setup under the stock valve covers. And mine are only 3 1/2 inches tall. Yours are 4 1/2 inches tall.
Old Jul 2, 2003 | 05:02 PM
ranger429's Avatar
ranger429
thanks airharley
Old Jul 3, 2003 | 02:39 AM
merc460's Avatar
merc460
Go to my gallery and there are some pic's off my engine with the covers off showing the guideplates, and screw in studs. Generally what it should look like although ,the rockers have not yet been adjusted in these pics. Eric
Old Jul 3, 2003 | 07:26 AM
ranger429's Avatar
ranger429
thanks merc460, the guide plates will be here today so i will be able to have it running by independence day
Old Jul 14, 2003 | 02:44 PM
manstruck's Avatar
manstruck
yes - you have to use guide plates with an adjustable valve train. DO NOT RUN THE MOTOR WITHOUT THEM.
Ed
Khauler
Mar 28, 2025 10:12 PM
brandon mauldin
Sep 23, 2014 12:55 PM
89stang
Mar 22, 2003 07:52 PM
BigJake86
Mar 15, 2003 08:26 AM
