E4OD trans and misc parts left over from ZF swap
Category: Accessories
Price: $350
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Engine: Part suitable for gas truck
I have an E4OD transmission from a 1994 F-250 2wd with 351 engine. The truck had 158,000 miles when the transmission was pulled. This tranny was the subject of a recent thread. I decided to swap to a ZF instead of upgrading the automatic for trailer pulling, just because I like stick better. I'm asking $350 obo, and I will offer a 30-day money-back guarantee provided that, at a minimum, you: (a) replace the input and output seals; (b) put a new filter in; and (c) give me a chance to help diagnose it if you have any problems with it.
I also have various parts left over from the swap, make an offer:
- auxiliary transmission cooler
- trans cooler metal fluid lines (they run to both the aux cooler and the truck's radiator)
- E4OD crossmember with gussets
- driveshaft stub (goes onto the trans output spline)
- instrument cluster (I swapped to a cluster with a tach)
- shift lever with OD Off button
FORDF250HDXLT
03-12-2020 04:30 PM
1994FordF-350MegaCab
04-01-2019 03:11 PM
delawarebill
04-12-2014 06:55 AM
