Compressor wheel question
Old Mar 13, 2014 | 10:31 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Anyone have an idea of how to make sure the impeller wheel is balanced? I see lots of things where guys just put them on and run fine but I also see people saying it MUST be balanced.
Old Mar 13, 2014 | 11:16 PM
Ford4Life7.3
Well i found the tq specs, its 50-65 INCH pounds. I also did some more reading and most say for a stock turbo it doesn't need to be balanced. For anyone who finds this down the road.
Old Mar 13, 2014 | 11:19 PM
1994F2507.3L's Avatar
1994F2507.3L
im running the riff raff wheel and had my turbo balanced, it did in fact need balancing and should be balanced any time you change the wheel from what i gather, if you change a tire you balance it, wouldn't it make since to hold the same principle to something spinning 20,000 + RPM on your engine? you can see where they had to grind to get it in balance on my new one, the shop also told me the spec is 100 in lbs
Old Mar 13, 2014 | 11:55 PM
Ford4Life7.3
well RiffRaffs instructions on their website don't say anything about balancing it and RiffRaffs instructions list the tq specs as 50-65 inch lbs....
Old Mar 13, 2014 | 11:56 PM
Ford4Life7.3
https://www.riffraffdiesel.com/conte...el_Install.pdf
Old Mar 14, 2014 | 05:07 AM
1994F2507.3L
ok well that is the borg warner wheel NOT the riffraff wheel that those instructions go to, so there may be a difference because the riff raff wheel is made from billet aluminum where that one is not, im not sure, im just telling you what the shop told me, and they don't say anything about balancing why i don't know that either, its cheap insurance the way i look at it, there are some people for it and some against it, i myself am for it because one my professor says its a good idea, two because to me its common sense that something spinning that fast should be balanced, and three a new turbo is upwards of 1200$ and i ain't got that cash just layin around.
RandomNewGuy
15
Aug 10, 2015 08:09 PM
BadDogKuzz
13
Dec 22, 2014 01:59 PM
spcw1234
Jun 19, 2011 05:55 PM
ramtruckman
Mar 15, 2004 07:57 AM
mueckster
Dec 24, 2003 07:07 PM
