Stock fuel pump. With 2 filters. One under cab in between tank and pump, one between pump and carb. Noticed that when carb leaks, the clear filter in between carb and pump goes dry. Stays full when it does not leak
At the bottom of the "stock" fuel pump, there is a glass or metal bowl retained by a bale. Inside this bowl is the fuel filter.
ok, so I insulated fuel line and also removed a gasket that I think was failing in between the body of carb and fuel inlet fitting and getting crap in needle seat. I saw the heat riser has been deleted by PO, I think it may have been a combo of problems...I will see if this fully fixes issue-thanks to all for the replies and help
The pic you showed is an Autolite/Motorcraft 1100 and I think they're superior. However I had to make some bracket extensions to make the linkage work on my 223. But as you can see in that pic, they are available with the Crapomatic can
