2003 tail gate latch broken
Old Mar 10, 2014 | 10:52 PM
salesman's Avatar
salesman
One side of the latch release handle on my 2003 is broken. How is it replaced or repaired?
Old Mar 11, 2014 | 07:18 AM
Josh S's Avatar
Josh S
If you remove the panel from the back side of the tailgate you will be able to see a lot more of the latch's inner workings. It basically operates like the manual twist turn on a garage door. When you lift the handle it pulls rods that are connected to the latches on each end of the tailgate. There's not much to it. If I remember right the side latches are each held in with two torx bits. Depending on what you find wrong with it a junkyard might be your best bet for replacement parts.
Bluegrass F250
Sep 3, 2020 10:45 PM
conchstew
Aug 21, 2012 01:25 PM
Ford1988Trucker
Aug 3, 2010 05:02 PM
1992F350
13
Jun 29, 2009 08:06 PM
dowdcl
1997 - 2003 F150
Jul 28, 2003 05:56 PM
