Beep / Tone when turning trailer
Old Mar 10, 2014 | 04:08 PM
rstazick's Avatar
rstazick
06 F-250 Lariat:
Bought a new tag along 2 horse trailer and when towing it home, turning sharp, had a beep / tone happen. It happened in mid turn, only lasted a couple of seconds. This has happened 3 times now, doesn't matter left or right. Nothing seems to be affected.
I have towed 2 different goose neck trailers and at least half a dozen other tag along trailers with no beeping. It sounds like a seat belt alarm tone.
I was thinking the built in brake controller may have lost connection momentarily. Any thoughts?
Thanks
Old Mar 11, 2014 | 07:46 AM
senix's Avatar
senix
Gave this some thought. I think a loose connection at the back of the truck might be the issue. The plug might be loosing contact.
I think the TBC is beeping because it is sensing a wiring fault for the trailer.
Check the pins at both plugs and make sure they are clean. Put a little grease on them as well.
Old Mar 11, 2014 | 08:19 AM
RV_Tech's Avatar
RV_Tech
Given the problem is only with this one trailer, I would start with the trailer. The seven pin cord on the horse trailer isn't so long it is catching on the fender in turns is it? I had to rewire one where that was the problem. It finally tore the seven pin cord off the trailer completely off.
Steve
Old Mar 11, 2014 | 08:38 AM
Schlava's Avatar
Schlava
This sounds dumb but does your truck have a back sensors? When the new trailer is hooked up to your truck is the box closer to the bumper? Maybe when you turn sharply the box is closer than other trailers and the sensors are setting off the alarm?
Old Mar 11, 2014 | 08:52 AM
RV_Tech's Avatar
RV_Tech
Interesting thought and certainly something I didn't think of!
Steve
Old Mar 11, 2014 | 02:10 PM
jdadamsjr's Avatar
jdadamsjr
my first question is are you backing up and the plug is loose ?
OR - you have an issue with the truck 'sensing' it is in reverse and no trailer connected - i.e. a wiring harness issue....
Old Mar 11, 2014 | 04:23 PM
spud57's Avatar
spud57
I'm with Scott on this. Loose connection with trailer plug.
Edit: The trailer plug on the trailer not the truck.
Old Mar 11, 2014 | 06:30 PM
RV_Tech's Avatar
RV_Tech
If the tone is from the controller signaling a disconnect, it has to be related to the trailer plug as doesn't happen with any other trailer. Has to be a trailer issue, if it were a truck seven pin issue, it should be happening with other trailers and OP said it does not.
My two cents,
Steve
Zach Keppley
All Things Towing
May 24, 2019 05:24 PM
JD'sBigredv10
Nov 18, 2018 09:47 AM
Don Schuler
Jan 25, 2018 12:44 AM
wb6anp
Jun 7, 2017 04:49 PM
rstazick
Mar 10, 2014 07:22 PM
