Beep while pulling a trailer on a sharp turn
Old Mar 10, 2014 | 03:43 PM
rstazick's Avatar
rstazick
06 F-250 Lariat:
Bought a new tag along 2 horse trailer and when towing it home, turning sharp, had a beep / tone happen. It happened in mid turn, only lasted a couple of seconds. This has happened 3 times now, doesn't matter left or right. Nothing seems to be affected.
I have towed 2 different goose neck trailers and at least half a dozen other tag along trailers with no beeping. It sounds like a seat belt alarm tone.
I was thinking the built in brake controller may have lost connection momentarily. Any thoughts?
Thanks,
Old Mar 10, 2014 | 04:18 PM
Iaff113's Avatar
Iaff113
Yeah that's most likely what it is. If you hear it look at the dash where the mileage is. It should say trailer disconnected on it, I have found this happens a lot when I pull my horse trailer, due to having to use a 7 pin adapter with it, really gets annoying after awhile. But when I use all my other trailers that use a 7 pin it never happens
Old Mar 10, 2014 | 05:20 PM
rstazick's Avatar
rstazick
Thanks, that is what I thought.
Old Mar 10, 2014 | 07:22 PM
mattdoc88's Avatar
mattdoc88
If you want to confirm this, you can hit the buttons on the brake controller when no trailer is connected - I think it makes a sound. See if that matches the sound you heard.
Zach Keppley
All Things Towing
May 24, 2019 05:24 PM
JD'sBigredv10
Nov 18, 2018 09:47 AM
tony montana 42
All Things Towing
Sep 13, 2017 10:11 AM
Michael53
6.7L Power Stroke Diesel
13
Feb 25, 2015 05:51 PM
rstazick
All Things Towing
Mar 11, 2014 06:30 PM
