power steering
Old Mar 9, 2014 | 04:04 PM
jeepy's Avatar
jeepy
power steering
adding power steering to my 66 f100 have everything put pitman arm gear box from 75 is that the arm I need ?also is that it steering wise?
Old Mar 9, 2014 | 04:13 PM
jowilker's Avatar
jowilker
The 75 had the Saginaw gear that will require a steering column swap as well. Not sure about pitman arm, I swapped it all in one piece.
John
Old Mar 9, 2014 | 05:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jeepy
adding power steering to my 66 F100, have everything but pitman arm, gear box from 75 .. Is that the arm I need?
D2TZ-3590-B .. Pitman Arm-Use with Ford/Saginaw P/S / Marked: D2TA-3590-BA / Obsolete
1972 F100/250 2WD from serial number M00,001 / 1973/79 F100/250 2WD Regular & Super Cab - Note: F250's under 8,100 lbs. GVWR
Old Mar 9, 2014 | 07:56 PM
dsrtjeeper's Avatar
dsrtjeeper
You can use your '66 F100 steering column. You need to cut 2" off the end of the shaft where it connects to the rag joint. You will cut the welds that hold the rag joint plate to the end of the shaft. Pull the plate off of the end of shaft. Cut about 2" off the end of shaft to allow for the longer steering box. Please measure before cutting. Slip the rag joint plate back on end of shaft, true it and weld. You may also have to slightly notch the driver's side engine mount near the frame. This will allow clearance for the longer steering box. You may need the steering linkage from a '73-'79 F100 but I'm not sure.
http://www.fordification.com/tech/powersteering.htm
I may have forgotten something here so look up forum users "Garbz" or Bill W.
Old Mar 10, 2014 | 05:01 AM
jowilker's Avatar
jowilker
dsrtjeeper, I believe one needs to cut the shaft about 2 1/3" shorter. If it is a 3spd, that can be a challenge.
John
Old Mar 10, 2014 | 07:03 PM
jeepy's Avatar
jeepy
coloum
if I find a 67-72 3 on the tree power steering column with the ford box it will bolt in correct?
Old Mar 10, 2014 | 09:23 PM
NumberDummy
if I find a 67 -72 3 on the tree power steering column with the ford box it will bolt in correct?
You won't find a 1966, 1967/68, or 1969 before serial number D96,001 w/a Ford box, because these trucks were only available with Bendix P/S.
It may be easier to find Amelia Earhart and/or Jimmy Hoffa, than a 3 M/T column with P/S. Very few trucks came with this combo.
Personally, I don't see the allure of swapping in P/S, because it's really only useful when parallel parking...in an empty parking space between two vehicles.
Old Mar 10, 2014 | 09:33 PM
jeepy's Avatar
jeepy
steering coloum
ok let me reword that if i find 69-72 power steering coloumn with ford box will it bolt in trying to avoid cutting mine and rebuilding cost for now
Old Mar 10, 2014 | 11:57 PM
dsrtjeeper's Avatar
dsrtjeeper
The newer used column would most likely need rebuilding anyway. I believe you can bolt in a '69-'72 PS column but you may need the power steering firewall plate. If you can even find a 3 on the tree PS column.
Old Jun 4, 2014 | 12:31 AM
vegasmax's Avatar
vegasmax
65 F100 disc brake & Power steering
In the process now have 75 parts, the steering box was missing, got this one:
Gear Box Atsco 7505 fits 68-79 Ford F-150 off Ebay still need pitman arm. Will the one that came off the 65 fit? Also bought a aftermarket steering column cost $170 shipped with tilt if you are doing a 65-66 with power steering I ordered the 28" and worked great! use the Rag joint off the 65 or 66 and then find the other 1/2 of the rag joint off something and cut if off the steering shaft, the drill out the old shaft to 3/4" , next get a 10" piece of Double "D" steering shaft. Summit sells it , weld it to the half of the rag you drilled the hold in and that is it. Very easy to do. The Double "D" slides inside the new steering column shaft so you can play with the length. I also bought a Ford type wood steering wheel w/Ford horn kit for $109.99 shipped. Worked out very nice. Also doing Vintage air as well.
Old Jun 4, 2014 | 07:11 AM
Shadowrider123's Avatar
Shadowrider123
My 75 parts truck F150 is a PS 3 speed column shift.
I need to get that project finished.
PS is also useful when backing a boat down a ramp.
Old Jun 4, 2014 | 08:51 AM
rusbukt's Avatar
rusbukt
Personally, I don't see the allure of swapping in P/S, because it's really only useful when parallel parking...in an empty parking space between two vehicles.[/quote]
I agree. But of if a guy or gal only weighs about a-buck-fifty. It's always fun watching them lift off the seat.
sonny1965
WTB - Parts & other
Nov 28, 2016 03:13 PM
Roger C
Oct 20, 2014 12:10 PM
55f100tx
Jul 13, 2014 10:23 AM
1965f100123
Jan 28, 2012 05:35 PM
pcta12
Sep 11, 2006 12:57 PM
