Tuning help
Old May 28, 2014 | 11:40 AM
Wolfracing's Avatar
Wolfracing
Tuning help
Ok. Usually smarter than this, but not used to these old Fords.
63 with 223 and three on the tree. Have had a chattering clutch problem especially at low speed. But if I am aggressive with the take off, it is much better. Had the clutch out and it looks good. Resurfaced the flywheel. Rebuilt the cab supports because they were gone and thought it might help. It helped a little. Mostly things just don't rattle around as bad.
Then the other day I had a thought and pulled the choke on a bit and the takeoff was better. So I ran the bottom metering screw out on the carb a turn, and that helped even with the choked off. Not a lot, but it was better. So now I am thinking the engine is just chugging at lower speeds. I have new cap and rotor and plugs and wires. no change. Checked the timing and dwell and both were ok.
I have cleaned a bunch of crud out of the carb due to a rusty tank.
Any suggesitons on the next thing to go after? I'm pretty sure at this point it is carb related.
Oh, I did run the valve lash on it as well, and it was fine.
Old May 28, 2014 | 12:09 PM
svolpone's Avatar
svolpone
fuel filter? that might help.
Old May 28, 2014 | 12:35 PM
Tedster9's Avatar
Tedster9
You're on the right track, the better the engine runs the better the torque and off idle acceleration will be. This helps with the clutch. I think the choke thing is compensating for this, shouldn't have to do that. A new distributor is often quite the bang for the buck. Advance weights get worn and such.
Most stock timing figures and advance curves are much too conservative, tuning the engine with a vacuum gauge and timing light costs next to nothing and can really allow for a lot more advance even with today's gasoline, this will make the bottom end a lot snappier.
Old May 28, 2014 | 12:37 PM
Wolfracing's Avatar
Wolfracing
Forgot. New pump and fuel filter. Resealed the tank.
Old May 28, 2014 | 12:38 PM
Wolfracing's Avatar
Wolfracing
OK. Something to try for sure.
Old May 28, 2014 | 12:45 PM
kjvforme's Avatar
kjvforme
Are you running Holley H-1 or the Autolite 1100?
Old May 28, 2014 | 12:57 PM
Wolfracing's Avatar
Wolfracing
Ahem....I don't exactly know but I think it is an Autolite.
Old May 28, 2014 | 01:13 PM
kjvforme's Avatar
kjvforme
Autolite 1100
http://www.gottafishcarburetors.com/...%20pic%204.jpg
Holley H-1
http://ecx.images-amazon.com/images/...kL._SX300_.jpg
Old May 28, 2014 | 01:21 PM
Wolfracing's Avatar
Wolfracing
It is an Autolite then!
Old May 28, 2014 | 02:05 PM
kjvforme's Avatar
kjvforme
Take a look at this....
Classic Inlines Autolite Carb's
Old May 28, 2014 | 03:01 PM
Wolfracing's Avatar
Wolfracing
Good read. I never thought about the balancer being turned too. May as well try some more timing and see what it thinks.
Old May 28, 2014 | 04:21 PM
kjvforme's Avatar
kjvforme
here is more information on rebuild if you needs it.
this is one of many that the guy has on Autolite 1100.
He has one on bench adjustment that might help.
Old May 28, 2014 | 07:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Auto-Lite (Ford) 1100:
Old May 28, 2014 | 08:05 PM
kjvforme's Avatar
kjvforme
Question on that, if it came out in 63 why wasn't it put in the supplemental manual?
Old May 28, 2014 | 08:09 PM
kjvforme's Avatar
kjvforme
Have another for you about Budd Bodies, non truck related, when did Ford stop using them?
