A/C Leak?
Old Jul 1, 2003 | 05:36 PM
kmorg's Avatar
kmorg
Question A/C Leak?
1000 miles on the truck. Been a little humid. In the morning, after driving about 7 miles to work, there is moisture on floor on passenger side. Doesn't do it any other part of day, only mornings. Not much water but it is closest to the hump. Normal? Condensation? Any Answers?
Old Jul 1, 2003 | 06:51 PM
LxMan1's Avatar
LxMan1
A/C Leak?
Could be condensation. Is it dry when you first get in it in the morning? I would also check the a/c drain on the firewall just to make sure it isn't clogged.
Jimmy
Old Jul 1, 2003 | 07:41 PM
kmorg's Avatar
kmorg
A/C Leak?
It is dry when I first get in. Where do I look and how do I check the ac drain on the firewall?
Old Jul 1, 2003 | 09:49 PM
LxMan1's Avatar
LxMan1
A/C Leak?
It should be towards the middle or towards the passenger side of the firewall. It is a short elbow runner tube that comes out then points down. I guess the easiest way to check it would be run the a/c on a/c not max for a while, then see if any water is dripping out of it. It should be dripping out if it is half way humid. Mine has never gotten the floor wet so I would think that it may have a clog in the drain.
Are you sure it is water and not anti-freeze? A seeping heater core perhaps? Just another Idea.
Jimmy
yasky69
Oct 4, 2016 07:34 PM
bulldog88
Aug 27, 2015 09:54 AM
jyarosz
2009 - 2014 F150
Aug 11, 2014 02:25 PM
johnarla
Mar 28, 2013 11:18 AM
LWolffe
Aerostar
Sep 19, 2003 05:30 PM
