Led Bulbs
Search post by kb1aah, should be the first on dated 05-23-2006. Very easy about 5 minutes. Instructions are excellent.
I have tried many versions of the seat belt chime removal, but so far none have worked. It only chimes about 6 times then stops. I can live with this, but like to hear about any procedures that works.
For Carfamilynj, you do know that 2014 will be the last of the E-Series. They are going to go with the transit design. Get your next one soon, while you can.....
What I do is to print out all of the mods and parts that are added to my vehicles, so I can track what was done when. Old habit left over from military career for troubleshooting. What was done last, is this a new problem?
Yes, would like the process to reprogram the multi- function box for the flasher slow down. Also any way to turn down the volume on the flasher?
)I was thinking of changing to the LED rear lights (taillight/brakelight/turnsignal)... and also could not find the "flasher" under the dash. This is on an 03 E250 factory incomplete chassis that has been converted (twice).
I was going to order the Superbright 3157 bulbs, but now not sure. I do not want to be doing any soldering or anything like that...
What would be needed for the 03 E250 to convert?
Thanks,
