Turn signal flasher
Old Oct 7, 2003 | 11:11 PM
embo69's Avatar
embo69
Question Turn signal flasher
98 Ford F-150, 6 Cyl, 2 whl Dr.
I bought some of those new fangled LED bulbs for my rear Turn/Brake light. My 4-ways blink normal, The turn signals blink fast. My ? is: Can I just change the flasher or do I need to get a resistor? Also I can't locate the flasher, where is it?
Under the dash is a relay, under the hood I think is the flasher but it's a 5-pin square one. The parts store gave me # 552 a vary load flasher. So...... where is the flasher and will that help or do I just put back the original bulbs. These new bulbs look great they can be seen at jamstrait.com
1 set of instructions say change the flasher, which I can't locate and the owners manual doesn't mention, the other instrutions say I need a cross wire/jumper resistor
plz help me out Thx
Old Oct 8, 2003 | 06:38 PM
13hondacr250's Avatar
13hondacr250
Most of the time there right on the fuse block.
I wonder if a heavy load flasher for like when using a trailer would help it out. If you have a stock one and put a trailer on with good lights it can make it blink faster.
Old Oct 8, 2003 | 07:59 PM
Franklin2's Avatar
Franklin2
The turn signal flasher assembly is located under the driver's side of the instrument panel, on the front of the fuse panel for the 1997-98 F-250HD, F-350 and F-Super Duty models and under the center section of the instrument panel in the relay/flasher block on all other models.
Here's a picture
http://www.cybrrpartspro.com/Chilton...9/91196p60.jpg
