The power windows aren't working and neither is the interior lights. I am hoping it is a couple of fuses. PRoblem is that I can't find a fuse diagram and I don't have any knowledge about changing the fuses. Do I need to change them both under the hood and under the dash?
Does anyone have info on which fuses I need to look at changing?
According to the wiring diagrams in the Chilton opened in front of me for 2000 & 2001 Excursions (17 bucks at O'Reilly's):
-For power windows check Relay 601 (30 amps) in the fuse box under the hood (driver's side corner) and Fuse 7 (5 amps) in the fuse box under the dash (driver's side).
-For interior lights check Fuse 107 (30 amps) under the dash as well as the Interior Lamp Relay, which I believe is marked "Relay 1" under the dash.
Any help is much appreciated!
You need to get an owners manual online, it's all in there.
