Power steering fluid smell
Old Mar 7, 2014 | 10:18 AM
Schlominator's Avatar
Schlominator
I have been noticing a humm from power steering when turning at low speeds. I am planning to replace the fluid. When I checked the level I noticed an unexpected smell - like a burnt electric motor. Is that just a normal smell for the well used fluid or is it pointing to something else?
And does anyone have a good picture or write up to replace the PST fluid on a 06 F250?
Thanks!
Old Mar 7, 2014 | 12:14 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The reservoir is in a different place, but all you do is hook a new line to the return out of the hydrobooster, and pump the brakes/ tunr the steering wheel.
My fluid was pretty nasty at 50k, and again at 80k. Smelled kind of burnt, too. But I put in Mobile 1 ATF and it quieted it down.
Old Mar 7, 2014 | 12:30 PM
Schlominator
Thanks TTDiesel! Should be completed shortly.
Old Mar 7, 2014 | 05:47 PM
69cj's Avatar
69cj
I also installed a Magnefine R038M filter in the return line. It not only has a filter but also a built in magnet to catch minute metal particles. Less than twenty bucks at:
www.emergingent.com/magnefine
I used Mercon V synthetic fluid for the flush.
Old Mar 9, 2014 | 10:44 AM
Schlominator
Thanks for the link 69cj. I'll take a look at that as well.
runawayhound
Jan 1, 2016 06:30 PM
wicat3
15
Sep 24, 2012 06:20 PM
berry1234
2004 - 2008 F150
Jun 12, 2012 02:19 PM
cujo8
20
Jan 4, 2007 11:09 AM
Bob Crain
May 19, 2005 04:59 PM
