Excursion shaking 45-50 mph?
Old Mar 6, 2014 | 10:36 AM
woochles's Avatar
woochles
Hey there. I have a 2001 5.4L excursion that intermittently shakes (feels like rumble strips/rough pavement) usually at 45-50 mph when the rpms are between 1500-2000. Increasing or decreasing rpms stopps the shaking. What could this be? I'm trying to figure out how much I might have to pay for repairs (pretty sure I'm not up to diying this one) without an expensive estimate.
Old Mar 6, 2014 | 11:01 AM
NorthwesternCowboy's Avatar
NorthwesternCowboy
How long since you've had the tires balanced?
Old Mar 6, 2014 | 12:33 PM
tdappleman's Avatar
tdappleman
So if you are 45-50mph and you take it out of overdrive (increasing RPMs) stops the shaking? Tire balance will be a constant vibration above 45 and RPMs will not be a factor but vehicle speed will be. It sounds like you have a misfire starting - when the engine is at lower RPMs and you give it slight gas it will most likely reproduce it.
Old Mar 6, 2014 | 09:22 PM
cpoer's Avatar
cpoer
Check out the Cardan joints. I had the same problem and pretty much had to replace the entire drivetrain.
Old Mar 6, 2014 | 09:37 PM
Faster71's Avatar
Faster71
I don't know if this will help but this winter I had the same thing. I took the truck to the car wash and washed the ice off now it is ok.
Old Mar 7, 2014 | 12:02 PM
projectSHO89's Avatar
projectSHO89
Pretty typical symptom of a mild misfire.
At around 45-50 mph with the transmission having just shifted into OD places the greatest stress on the ignition system. To check, simply press the OD cancel button and rev up the engine to maintain ground speed. If it clears for the moment, it's almost always a misfire.
Once accurately diagnosed, you can usually fix it for around $50 in Motorcraft parts.
Old Mar 7, 2014 | 08:12 PM
woochles's Avatar
woochles
SO if I take it to a parts store and have them run a code check that should tell me if there's misfiring and which cylinder(s)? I've tried turning the overdrive off and that doesn't seem to help.
Old Mar 7, 2014 | 10:13 PM
projectSHO89
The parts stores will only be able to help if the check engine light is on.
Old Mar 8, 2014 | 09:44 AM
tdappleman's Avatar
tdappleman
If turning off the OD didn't change the vibration then you are back to it most likely being a balance issue. RPM's will affect the misfire - speed will be the factor with an out of balance tire. It's time to take it to a shop and let them check the balance. If the balance is ok then they should be able to run a cylinder contribution test or Mode 6 test to try and identify the offending cylinder.
Old Mar 8, 2014 | 10:47 PM
ssolid's Avatar
ssolid
Similar problem
I had a similar problem and it was simply the front stabilizer bar....thought it was the calipers...best of luck. THis is definetly the place to find the answer.
ssolid
SuperDuty93
Oct 30, 2013 08:23 PM
f15097
1997 - 2003 F150
May 5, 2008 10:08 PM
chevy_20
Jan 11, 2005 05:29 PM
4x4x4x4
Aug 9, 2002 09:11 PM
