1994 front end
Old Jul 1, 2003 | 02:51 PM
hondo ford's Avatar
hondo ford
Question 1994 front end
I have a 1994 f150 custom. It is two wheel drive, long wheel base ,six cylinder, automatic. I wrecked it and ruined the steering box, right radius arm, right I-beam and the right radius arm bracket. I was wondering if anybody knows what year models would have the same front end? Thanks for any replies. Fletch
Old Jul 1, 2003 | 08:00 PM
ecarter50's Avatar
ecarter50
1994 front end
Any 80-96 F150/Bronco 2wd or 4wd front suspension will bolt in. Sounds like a good time to convert to 4wd to me.
Old Jul 1, 2003 | 11:10 PM
optikal illushun's Avatar
optikal illushun
1994 front end
yup like said above, if ur gunna convert to 4wd, get a doner truck with the whole front end assebly and swap it over (front axle, transfer case, etc...). but if ur just going to return it back to stock then any 80-97 f-150/bronco 2wd will work.
Old Jul 1, 2003 | 11:23 PM
MustangGT221's Avatar
MustangGT221
1994 front end
The brakes are different on some models. I believe the year-break was 88ish. For safety, I'd get a 92-96 model.
Old Jul 2, 2003 | 06:35 AM
RoadRash's Avatar
RoadRash
1994 front end
Yes, 80 to 96 will work. I have an 84, 88, 93 F150 4x4's all with the same front brake setup. My 94 has a different setup. If your looking for a quick repair I would use 94 to 96 2wd. If your going 4wd any will do.
Old Jul 2, 2003 | 08:34 AM
MustangGT221
1994 front end
I believe the brake calipers mount in a different way on the older models.
Old Jul 2, 2003 | 10:01 AM
steve83's Avatar
steve83
1994 front end
Before ~'84, the caliper was retained by a key with a spring and a bolt. After that until ~'95, it used 2 rubber-filled stainless clips. The Bronco went to a floating caliper (2 bolts with rubber boots) in ~'95, so I suspect the pickups did, too, but I've never checked.
The '87-88 D44IFS w/manual hubs was unique, so avoid it no matter what you do.
Old Jul 3, 2003 | 10:05 PM
RoadRash's Avatar
RoadRash
1994 front end
94 was the first year for the "2 bolt" calipers in the F150, as my 93 F150 has the "2 plate/rubber" combo, and my 94 has the "2 bolt" setup
panfour
Dec 5, 2012 03:34 PM
Al Cowlings
1978 - 1996 Big Bronco
Jan 5, 2011 12:18 AM
dcrewchief
Oct 21, 2004 11:48 AM
kgrat
Jun 29, 2001 11:19 PM
