1978 - 1996 Big Bronco
Front end creaking
Old Jan 4, 2011 | 07:57 AM
Al Cowlings's Avatar
Al Cowlings
Front end creaking
This summer I had to replace the radius arm bracket on my 1994 Bronco. The stock bracket had cracked and broke around the bushing. Since the replacement the front end creaks when I first start to backup or going over any bumps. I Have looked the bushing over and they look ok to the eye, ball joints are tight, and steering linkage is fresh(replaced before radius arm issue). Is there anything else that could be causing the front end noise. Also all front end bushings were replaced within the past three years. Thanks in advance for any feed back.
Old Jan 4, 2011 | 11:12 AM
greystreak92's Avatar
greystreak92
In addition to the radius arm bushings and ball joints the Bronco has:
2 axle pivot bushings
4 tie rod ends
2 or 4 front shock absorbers each with a top and bottom bushing
Old Jan 4, 2011 | 03:06 PM
1995Bronco351's Avatar
1995Bronco351
My 95 too!
Guys,
My 95 does the same thing. I replaced the radius arm bushings too (as the right hand side always disintegrates due to the proximity to the catalytic, ergo the extra heat shield, which doesn't do ****) but now I have the metal rub squeek as well. I get it when I turn my wheels when parked and over some speed bumps too, Weird. Let me know your thoughts.
Big T
Old Jan 4, 2011 | 07:58 PM
Al Cowlings
I read about a Ford service bulletin that some of the noise comes from frame rivets. On FSB some of the guys say you can run a weld bead around some places on the front of the frame and it will take care of some of the squeaking when the wheels are turned. I am not sure where you need to weld but that might be some help for you Bronco351.
Old Jan 5, 2011 | 12:18 AM
Encho's Avatar
Encho
The Southernmost Mod
Hmmm, i have that exact issue you described, i'll keep an eye on this thread to see if any solution comes up.
wbulick76
Jun 17, 2009 07:36 AM
ThePheonixx2
Aug 25, 2003 11:31 AM
kgrat
Jun 29, 2001 11:19 PM
mgh
Apr 3, 2001 08:36 AM
cgl
Jul 1, 2000 04:38 PM
