Radius arm bushing
Old Jun 27, 2001 | 07:02 PM
kgrat's Avatar
kgrat
Radius arm bushing
Hello folks,
I need to get the passenger side radius arm Bushing replaced.
What's a good price for this job at a front end shop?
Thanks
John..
Old Jun 27, 2001 | 08:32 PM
ih8jfgrdn's Avatar
ih8jfgrdn
Radius arm bushing
I paid a shop $125.00 to replace both of mine, but I gave them the parts, so it was all labor, but they did have to grind and chisel all the rivets out of them, thats the only reason I didnt do it myself, but now i can with just bolts in it
Old Jun 28, 2001 | 12:11 AM
shotgun's Avatar
shotgun
Radius arm bushing
I thought you would have to grind rivets, also. Then I read the manual. The first side took a little over an hour, other side went a bit faster.
Basically you:
Lift the front end.
Loosen the spring and shock (one side at a time)
As the Tire/TTB drop down a few inches it will allow the TTB to pull forward a little. This allows the rear of the radius arm to pull from its mount once you remove the big nut behind the bushing. (Some people use a "Come-along" to whinch the axle assembly forward).
Install the new bushing.
Re install everything in reverse order.
Pretty easy, huh? A $12 repair manual explains it pretty good.
If your exhaust runs close to either side radius arm bushing ensure you use a heat shield cup. A lot of people go with Polyurethane bushings. Supposed to last a lot longer and are as cheap as factory parts, maybe cheaper. Ask about them at any 4x4 suspension shop.
Chris
Old Jun 29, 2001 | 02:26 AM
knuckles's Avatar
knuckles
Radius arm bushing
[font size="1" color="#FF0000"]LAST EDITED ON 29-Jun-01 AT 03:26 AM (EST)[/font][p]Please don't use a come-along to pull your I-beam forward.
Best case sceanario, you severely shorten the life of the I-beam pivot bushing.
Worst case scenario, you destroy the bushing immediately.
Spend the extra 1/2 hour and drill or cut the rivets from the Radius arm bracket. It's cheaper (and smarter) in the long run.
Old Jun 29, 2001 | 07:53 PM
billyb's Avatar
billyb
Radius arm bushing
i figure that while your replacing the radius arm bushing, you might as well replace the pivot bushings.
Old Jun 29, 2001 | 10:55 PM
knuckles's Avatar
knuckles
Radius arm bushing
If you're going to do that, then there's no need to cut or grind anything. The I-beam or TTB must be removed (or at least lowered) to replace the pivot bushings, which lets the radius arm fall right out of the bracket. The pivot bushings last at least 2x-3x longer than the radius arm bushings, so there's usually no need to replace them unless some flat-rate monkey has butchered them.
Old Jun 29, 2001 | 11:19 PM
PAUL_2's Avatar
PAUL_2
Radius arm bushing
John in Vegas
Sep 25, 2013 10:27 AM
1944sak
16
Apr 16, 2011 10:34 AM
Rstrause
Nov 10, 2004 11:57 AM
warema
1978 - 1996 Big Bronco
Dec 8, 2003 10:00 PM
Mexray
Apr 6, 2002 04:47 PM
