Smell of raw fuel on hard excel.
Old 03-05-2014, 07:32 AM
Hotwheelbill's Avatar
Hotwheelbill
Hotwheelbill is offline
I have noticed a smell of raw fuel when I roll into it WOT. It does not happen every time and only when WOT. Hangs in the cab for a while too. I have stopped right away a few times to look and can not seem to find the leak. I did do the blue spring up grade but see no leaks there. I also changed both fuel filters a while back and have not seen any leaks, but have not rolled all the way under the truck when it happens, just look for any moister on the frame. Any ideas as to where or how to find the leak?
Old 03-05-2014, 09:38 AM
mhoefer's Avatar
mhoefer
mhoefer is offline
Double check the fuel line and return lines on the fuel module. I assume when you did the blue spring you had these off. Make sure you use two wrenches and be gentle. Perhaps take apart and check the o rings? Mine gave me a few fits trying to get the big line bolted back up straight and tight.
Old 03-05-2014, 05:39 PM
Hotwheelbill
OK. That gives me a new place to look. Thanks.
Old 03-06-2014, 07:39 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Going WOT won't increase your fuel pressure or chances of a fuel leak, it should actually decrease your chances of a leak because of lowered fuel pressure. Since the pump is electric and not mechanically driven you should have higher fuel pressure at idle. I suspect what you're smelling is raw unburned fuel from an exhaust leak.
Old 03-06-2014, 08:27 AM
RideDiesel88's Avatar
RideDiesel88
RideDiesel88 is offline
That's exactly what I was thinking. Cracked y pipe. Goes right into the cab. I doubt it's unburned also.. Why would it be raw unburned fuel? What's your fuel pressure? Normal? Any smoke out exhaust? I bet it's just exhaust from a cracked y pipe. I'm on my third one. Aftermarket without expansion joints.
86f250XLT-4x4
12-29-2013 01:50 PM
97F250LD4X
Modular V8 (4.6L, 5.4L)
05-30-2010 08:52 PM
tdorval
02-02-2009 07:19 PM
fridgeddiesel
36
01-03-2009 08:40 PM
gomfrddy
11-27-2005 04:14 PM
Quick Reply: Smell of raw fuel on hard excel.
