Sponsored by: Auxito
door lock problem
Old Sep 30, 2003 | 06:08 AM
bgdgtch's Avatar
bgdgtch
Question door lock problem
Hi all,
First time poster, long time reader here. I've come across a problem with the door locks on my in-law's 99 F-150. The locks will not lock or unlock with the remote or at the door switches.
When I hit the remote I can hear the relays inside the truck click. The fuse is good but when my father-in-law took it somewhere to have it looked at they put in a 30a fuse when all is required is a 15a. According to my book, it seems the problem is in the door switches or the door motors.
I am worried that by putting in the larger fuse they may have burned the door lock motors or the lock switches. Any ideas on how to proceed. I was thinking about putting the swithces from my truck(97 F150 ) in to his to test them, but I am worried they might get burned as well, if that is the problem.
Thanks for any help you can give.
Old Sep 30, 2003 | 11:36 AM
bgdgtch's Avatar
bgdgtch
Can anyone give me a suggestion on this one?
Old Sep 30, 2003 | 12:13 PM
AegisSailor's Avatar
AegisSailor
The only thing I can think of is to run a jumper directly to the lock motor, bypassing the switch and relays. If the motor operates, then you can rule that out.
Old Sep 30, 2003 | 08:22 PM
bgdgtch's Avatar
bgdgtch
good idea, i'll try that asap and let you know how it comes out.
