4WD trouble
Old Mar 4, 2014 | 08:15 PM
narfzort's Avatar
narfzort
4WD trouble
Hello, My 2007 F350 started having 4WD engagement issues today. When I turn the dashboard switch to 4WD-HI the yellow 4WD-HI dash light comes on but the hubs do not engage. If I lock them manually, I have 4WD. When I place the switch in 4WD-Low, the yellow light stays on 4WD-HI and the transfer case remains engaged in 4WD-Hi. The dashboard vent controls seem to work, so I think I have vacuum. All fuses seem good. Any thought? Thanks.
Old Mar 4, 2014 | 08:29 PM
holdtyte's Avatar
holdtyte
Are you in Neutral when you switch to 4Low?
Old Mar 4, 2014 | 08:55 PM
78fordman's Avatar
78fordman
Engage the 4x4 and lock in one side at a time. See if locking in just one side will gain 4x4 operation. If it does you probably have a hub which either needs replaced or needs lubed. If both sides have to be engaged, check the solenoid on the passenger side fender near the vac pump. If you are maintaining climate controls and not going to defrost, I doubt you have a vac leak.
Sent from my leash using IB AutoGroup
Old Mar 4, 2014 | 09:20 PM
Yahiko's Avatar
Yahiko
Where is the heater blowing out from?
Are you finding that when you switch the 4X4 on that it
no longer blows out the vent but goes to the defroster?
Sean
Old Mar 4, 2014 | 09:28 PM
narfzort's Avatar
narfzort
Thanks. I've tried switching to 4WD-Low fron Neutral and Park, no go. I have not tried locking the hubs one at a time, I'll try that asap. All vents are working properly, I have full control over the all vent postitions in 2WD and 4WD,
Old Mar 4, 2014 | 09:36 PM
78fordman's Avatar
78fordman
Did you have the brake pressed while in neutral when trying 4x4 low?
Old Mar 5, 2014 | 12:06 AM
AlaskanF350's Avatar
AlaskanF350
jumping in cause I want to learn here...
What does the defrost tell us??
Still learning on my 6.0
Chris
Old Mar 5, 2014 | 12:42 AM
jswartz84's Avatar
jswartz84
Chris
That you have a vacuum leak.
Old Mar 9, 2014 | 02:39 PM
grantpage's Avatar
grantpage
Has anyone used anything other than OE hubs? I have one hub not locking now and one hub making noise(when I take it off the truck, the insides seem very loose/worn), probably replaceing them this week, the Ford hubs are a little pricey.
Old Mar 9, 2014 | 04:50 PM
mhoefer's Avatar
mhoefer
Warn makes a locking hub for the 2003-2004, but not for the 2005 - 2007 series.
Old Mar 9, 2014 | 05:51 PM
Yahiko's Avatar
Yahiko
Try looking here >>> AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
They have some good pricing. They are also a FTE supporter.
BTW the belief is that Warn makes the hub for Ford and that is
why they don't sell an aftermarket unit.
Sean
Bowie
Jul 1, 2014 07:10 AM
cuttn4fun
Nov 21, 2012 12:01 PM
BWPowersmoker02
22
Jun 20, 2012 08:28 AM
hdcnick
Mar 23, 2011 10:32 AM
jhpowerstroke
Jul 17, 2009 03:43 PM
