how much do you drain
Old Mar 4, 2014 | 05:18 PM
KDAVID1's Avatar
KDAVID1
So I had water in the fuel and drained about 16oz of deisel and no.more message. Well it can on again today. I will ne changing filters this weekend but was wondering how much should be drained when this comes up. Thanks in advance
Old Mar 4, 2014 | 05:46 PM
69cj's Avatar
69cj
If it keeps repeating and there actually is water coming out, I would drop and empty the tank. Cheaper than injectors.
Old Mar 4, 2014 | 05:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
And if no water is coming out with the diesel the sensor is corroded.
Josh
Old Mar 4, 2014 | 06:13 PM
KDAVID1's Avatar
KDAVID1
I bet that us it since no water came out last time.
Old Mar 5, 2014 | 12:58 AM
AlaskanF350's Avatar
AlaskanF350
I had some bad fuel back in november...
I had to drain weekly... getting only a trace of water per about a cup of fuel..
finally had to go drastic and get tank pumped and two sets of filters...
so... could be same thing- water/fuel separater only gets so far- than you got to drain
good luck,
Chris
Old Mar 5, 2014 | 02:20 AM
Yahiko's Avatar
Yahiko
Also sometimes algae will build up in the housing and trigger the sensor
if it has not corroded it. Then you can spray some carb cleaner in with
the plastic straw that comes on the can. The other option is remove the
cover and clean the gunk out. You want a replacement gasket and if you
find a bad sensor you need a cover. You can get it with or without the
new style drain plug. If you don't have the new plug I would get it.
So much less of a pain to drain with the new brass plug.
http://www.ebay.com/itm/NEW-OEM-Ford-6-0L-Diesel-Fuel-Pump-Header-Inlet-Outlet-Manifold-WIF-Sensor-/271220606731?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2602070b&vxp=mtr
Sean
Old Mar 5, 2014 | 04:35 AM
AlaskanF350
good to know about using carb cleaner
Chris
Old Mar 5, 2014 | 05:51 AM
KDAVID1's Avatar
KDAVID1
Cool deal!!
Old Mar 5, 2014 | 07:25 AM
Monty Simmons's Avatar
Monty Simmons
Josh
How does one tell if water is coming out? Does pure water come out or is it a fuel water mixture?
Do you drain the fluid into a glass jar and see if the water an fuel separate?
Why did Ford not use a filter that does not allow water to pass. My bobcat and my 55 gallon fuel tank with electric pump have such filters.
Old Mar 5, 2014 | 07:39 AM
Money-Pit's Avatar
Money-Pit
Motorcraft and Racor filters do block the water with a filter media called "Aqua-bloc"....and the water stays right there, hence the reason to drain it.
bbender85's Avatar
bbender85
Originally Posted by Yahiko
...The other option is remove the
i'll vouch for the gasket. i tried reusing mine when i removed the cover a few weeks back and spent two days trying to diagnose a no-start condition after putting everything back together.. was that gasket.
be prepared and buy it online; i had mine apart and taking up space in my buddy's shop, so i had to get the gasket at my local stealership in a pinch... to the tune of $55.
Old Mar 5, 2014 | 08:27 AM
KDAVID1's Avatar
KDAVID1
ouch--you definitely have to plan ahead to save $$ I'm finding out
Old Mar 5, 2014 | 08:39 AM
bbender85's Avatar
bbender85
for sure. think i saw them for under $30 with shipping online somewhere.
Old Mar 5, 2014 | 08:55 AM
Yahiko's Avatar
Yahiko
Gasket and hardware kit on Flea-Bay for $35.00 Free shipping.
http://www.ebay.com/itm/231057967958?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Sean
Old Mar 5, 2014 | 09:11 AM
Monty Simmons
Ok, did a little research and I see how the system works now.
I am not very impressed with the engineer who designed this fuel/water separator system. Problems include (1) water storage limited, (2) drain system design is as ignorant a design as anyone could have envisioned particularly considering where the drain is located.
Oh well, in any event, is there an aftermarket separator drain system out there for the 6.0?
